Old 10-11-2019, 03:57 PM   #1
Fourspd2quad
Fourspd2quad's Avatar
Default Axle Quick fix seals which direction?
Which pic is correct? Either way the keyway interrupts the seal.
Thanks in advance.
File Type: jpg FC916D07-2779-41E3-BC55-F78717AB23BF.jpg (54.1 KB, 189 views)
File Type: jpg AF81607E-602B-4C14-B09C-A617EEB4C37C.jpg (53.3 KB, 192 views)
Fourspd2quad is offline   Reply With Quote
Old 10-11-2019, 04:13 PM   #2
jimTN
Default Re: Axle Quick fix seals which direction?
Never seen one quite like that, anyway the lip should go to the inside where the liquid grease is. The "fix it seals" I have do not interfere with the keyway and to not have that protruding part.
jimTN is offline   Reply With Quote
Old 10-11-2019, 04:47 PM   #3
19Fordy
19Fordy's Avatar
Jim, Please post photo of Quick Fix seals you have. Never heard of them.
Old 10-11-2019, 04:59 PM   #4
Fourspd2quad
I think the flange gets pushed in flush to the housing and the lip gets pushed in the gap between the axle and housing however it would be a pretty tight fit
Old 10-11-2019, 05:12 PM   #5
Mart
Mart's Avatar
Like in the 2nd or right hand pic. In that pic it is not pushed all the way in, though. It wants to be pushed as far in as it will go.
Mart.
Old 10-11-2019, 06:13 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
These are some pics from another source.
Old 10-11-2019, 06:23 PM   #7
Fourspd2quad
Awesome Thanks!
Old 10-12-2019, 11:43 AM   #8
Fourspd2quad
Dont know what the deal is on my end but these are the National seal numbers 6510 marked on the box and gasket and they are way too tight a fit to the housing. I tried pulling it in with the hub and nut, tapping it in etc and starting to damage the seal. Looks like a no go.
Old 10-12-2019, 12:15 PM   #9
Fourspd2quad
Here is the seal and box it came in.
File Type: jpg E0D4F202-BB1D-49EA-BB5B-09D3D6D8B6AA.jpg (37.5 KB, 63 views)
Old 10-12-2019, 04:43 PM   #10
jimTN
I have not had time to dig out my seals but will try to locate them tomorrow and take a pic.
Old 10-12-2019, 06:10 PM   #11
Fourspd2quad
Thanks. My seals are about 1 3/8 diameter.
Old 10-12-2019, 08:32 PM   #12
40 Deluxe
Thanks in advance.
Either my eyes are deceiving me, or there already is a seal installed in the hub.
Old 10-12-2019, 09:21 PM   #13
51 MERC-CT
51 MERC-CT's Avatar
Good catch, sorta looks like some kind of a seal to me also.
Old 10-13-2019, 07:40 AM   #14
Kube
Kube's Avatar
Okay, I have a question... "Why not simply replace the factory installed seal"?
That seal does the job quite well. And, obviously - it fits.
Old 10-13-2019, 09:45 AM   #15
51 MERC-CT
51 MERC-CT's Avatar
Have to agree.
The instructions on the quick seal box indicate that the original seal/grease retainer has to be removed anyway to give access to the axle housing race.
Old 10-13-2019, 10:03 AM   #16
Mart
Mart's Avatar
Mis information above, sorry.
Obviously, the advantage of the Quick seals is that they can be fitted without having to strip the rear end assembly down. The seal in the second pic in the first post is not the stock seal, but possibly another variety of quick seal.
To change the stock seals the whole rear end must be stripped down. They are fitted inside the axle casings.
The quick seals may not be as good as the stock seals, but they are really a lot easier to fit and quicker in a service scenario when time means money.
I'd use them if I could find a supply here in the UK.
Mart.
Old 10-13-2019, 10:14 AM   #17
Kube
Kube's Avatar
Mart.
I understand Mart. However, I don't believe any of are any longer in a "service scenario" at this stage of life.
I dunno, I guess I just prefer doing it right the first time even if it takes a little longer to do so.
Pulling the axle housing(s) is not that big a deal.
Old 10-13-2019, 10:57 AM   #18
Fourspd2quad
I looked really closer with a lens and there definitely isn't a seal in there. These are 35-36 bells on an otherwise '40 rear. I don't know if that changes the scenario any.
Old 10-13-2019, 11:00 AM   #19
deuce_roadster
deuce_roadster's Avatar
I agree with Kube, by using a micrometer and replacing the banjo gaskets with exactly the thickness that was there, it doesn't take all that long if you have a good spring spreader. Granted, I have the KRW tools to achieve this which helps, but a home made tool could quickly be made to install the new seal. The old seal knock out easily toward the large end of the axle housing.
When I started working on cars at age 12, I thought that gear oil was there to lube the roller bearings on my 1930 Model A!!
Fourspeed, it is in there where you can't see very well, maybe 4 or 5 inches.
Old 10-13-2019, 11:06 AM   #20
Fourspd2quad
Thisi thread really belongs on the HAMB as my car is a rod but I figured there would be more knowledge over here on this subject. That being said I have a lot going on in order to pull the axles off as my axle is tucked up into the trunk area. I have a spring spreader however and may just have to bite the bullet and replace the factory ones. It just puzzles me as to why these repair seals wont work in my application.
