11-16-2021, 06:05 PM | #1 |
Emergency Brake Actuating spring
After spending hours sanding all the bumps and nicks from the toggle shafts and actuating arms key ways the spring was simple ! A little grease slip the spring on then the arm tap tap hook the spring well almost that easy . My special tool made the job easy took seconds to hook the spring .
Dennis in Kelsey ca |
11-17-2021, 01:42 PM | #2 |
Re: Emergency Brake Actuating spring
