Old 11-16-2016, 07:40 PM   #1
ModAfan
ModAfan's Avatar
Default Name of item please
Anyone know what this contraption is called? Also, should the rod on the top right be bent?
Thanks.
ModAfan is offline   Reply With Quote
Old 11-16-2016, 07:48 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Name of item please
Not that I have seen a real, live one but I think that is the gizmo that goes on the back of the block to work the accelerator on a LHD car. I've only noticed them in pictures of the engine. We use something vaguely similar but much heavier to operate the starter.
Old 11-16-2016, 07:55 PM   #3
pooch
pooch's Avatar
It is an accelerator pedal mover acrosser. for want of not knowing the factory term.
It looks like a left hand drive assembly, but something just doesn't look quite right .
Maybe it is just the way the pic is taken, but wonder if it has been dismantled and put back together wrong ?
pooch is offline   Reply With Quote
Old 11-16-2016, 07:57 PM   #4
pooch
pooch's Avatar
Yep, that does now look like a right hand drive starter mover acrosser after Synchro mentions it.
Although the bent rod on the left makes it look like an accelerator rod throttle actuator.
A starter button would not need that .
Old 11-16-2016, 08:03 PM   #5
Synchro909
Synchro909's Avatar
If that is what it turns out to be, I want it! I've had to fabricate a couple of them - fiddly.
Old 11-16-2016, 08:06 PM   #6
Bob C
Early 1928 throttle control assembly, used from the beginning til May 1928.
Bob
Old 11-16-2016, 08:08 PM   #7
700rpm
700rpm's Avatar
It is an early 28 accelerator assembly. It attaches to the back side of the block, at the top. It has nothing to do with the starter.
Ray Horton, Portland, OR
Old 11-16-2016, 08:09 PM   #8
700rpm
700rpm's Avatar
Bob C. is a faster typist than I.
Old 11-16-2016, 08:09 PM   #9
Synchro909
Synchro909's Avatar
On closer inspection, it's not a starter mover acrosser. I'm back to throttle mover acrosser.
Old 11-16-2016, 08:27 PM   #10
ModAfan
ModAfan's Avatar
Thanks to all. Forever4 nailed it with the Ford Garage reference. It has the same bend in the top rod. The car is a LHD May 1928 Tudor. The engine is being rebuilt, so I thought it would a good time to clean up, what turned out to be, the Throttle Control Assembly. Great site.
Old 11-16-2016, 09:14 PM   #11
larrys40
Just so you know...It is Vince's site ( forever4) and certainly an asset to us all. He has spent countless hours compiling data that adds up to countless years .... thank you Vince!
Larry
larrys40 is offline   Reply With Quote
Old 11-16-2016, 09:34 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
Also notice that the throttle linkage has two oil holes that should get oiled a few times a year. Also oil the distributor often by filling the oil tube to the top.
Old 11-16-2016, 11:04 PM   #13
quickchange
quickchange's Avatar
Any one need I have a box full , some earl some later , all lhd ones , Derek on the shaky island
quickchange is offline   Reply With Quote
Old 11-17-2016, 03:22 AM   #14
updraught
updraught's Avatar
This photo has the RHD starter one. I think the pedal breaks off and they get chucked and replaced by a solenoid and button. I think I've only come across one good one.
The gas pedal is a bit harder to replace with fly by wire.
updraught is offline   Reply With Quote
Old 11-17-2016, 07:46 AM   #15
Tom Wesenberg
Is this for parts, or a future project?
On the right side frame rail at the bottom of the picture, what is the bracket bolted to the top of the rail?
Old 11-17-2016, 10:23 AM   #16
d.j. moordigian
d.j. moordigian's Avatar
Originally Posted by forever4 View Post
http://www.fordgarage.com/pages/throttlecontrols.htm
Read all about it in the link above.
LMAO...........still waiting for a photo of #2
d.j. moordigian is offline   Reply With Quote
Old 11-17-2016, 10:30 AM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
BOY, there's LOTS of strange stuff on a RHD! The pic makes you think you're having a confusing DREAM!!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 11-17-2016, 11:47 AM   #18
Bob C
Looks like the stop light switch.
Bob
Old 11-17-2016, 12:20 PM   #19
700rpm
700rpm's Avatar
Bob
I can't imagine getting my big feet to and from that accelerator pedal in any safe amount of time.
Old 11-17-2016, 01:16 PM   #20
Cool Hand Lurker
Cool Hand Lurker's Avatar
Wow. How come those guys on the bottom of the world always put everything in backwards and upside down?
But then I guess we DO learn something every day, eh?
Cool Hand Lurker is offline   Reply With Quote
