Go Back   The Ford Barn > The Archives > Late V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default 55 Merc Carb Specs
Finally located a carb kit from a local supplier here in Spokane, but no spec sheet was included. Does anyone have the correct spec for for the float setting? It is the original Holley 2140 series 2 barrel on this 55 Merc Parklane w/ a 292. We've looked at several books and have several different specs. ??? May have to resort to trial and error?
Thanks in advance for any help.
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: 55 Merc Carb Specs
that carb was used on 1954 models, 1955 used the 4000 model, on the 2140 idle screws turned out 1 1/4 turns,when the float shuts off the fuel there should be 1/2" form the gas to the top of the carb main body, turn engine over till float shuts off fuel take top off of carb then measure
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
Thanks for the info. Interesting about the model of the carb by year. The carb is the original and the owner is also the original. Ford must have had some inventory left over into 55.
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
yes either left over inventory or an early production car
