Old 09-24-2023, 11:24 AM   #1
Farley's34
Default 40 DeLuxe vs. 39 DeLuxe Hood
I have a 40 Sedan Delivery that someone de-trimmed, welded and leaded the hood. Would a 39 DeLuxe hood and grille fit without any problem ? How about the 39 hood and using a 40 Standard grille ? Thanks, Jeff
Farley's34 is offline   Reply With Quote
Old 09-24-2023, 11:52 AM   #2
47topless
47topless's Avatar
Default Re: 40 DeLuxe vs. 39 DeLuxe Hood
As I recall, the latch hardware is different on a 39 DLX and a 40 STND.
47topless is offline   Reply With Quote
Old 09-24-2023, 01:15 PM   #3
Kube
Kube's Avatar
A '39 deluxe hood is completely different in shape to that of a '40 deluxe.
However, you could swap the grille and the hood without issue.
Old 09-24-2023, 02:16 PM   #4
47topless
47topless's Avatar
From his post, I assumed he wanted to use a 39 DLX hood, not a '40.
Old 09-24-2023, 03:19 PM   #5
Karl Wescott
Karl Wescott's Avatar
To expand on what Kube stated: The 1940 DELUXE hood mates ONLY to the 1940 DELUXE grille.
1939 Deluxe and 1940 Standard and 1941 Sedan Delivery hoods share the same base stampings but with different cutouts for trim, and can be interchanged with appropriate hole adding and filling.
A 1939 Deluxe grille/hood combination would be a bolt on modification to replace 1940 Deluxe... but the delivery would clearly be a modified 1940-41 (not that it would not look GOOD), as could a 1940 Standard or 1941 Sedan Delivery grille/hood combination.
Karl Wescott is offline   Reply With Quote
Old 09-24-2023, 09:26 PM   #6
Farley's34
I do recall early and late 39's having a different latch design. Thank You for the clarity men.
