12-15-2016, 10:21 AM | #1 |
Valve springs
I have wondered if there is a shade tree mechanic way of testing valve springs to see if they have the required tension. Any thoughts. Jack.
12-15-2016, 10:45 AM | #2 |
Re: Valve springs
12-15-2016, 10:51 AM | #3 |
Re: Valve springs
Hmmm, since my neighbor owns the tree and all I do is use the shade, I would think that if you had valve spring problems you could find it if you did a "leak down" test, but that would also show if you had a ring problems. Short of removing all the springs and having them tested for conformity, I can't think of anything else "in motor" to do it.
New owner of '28 Tudor Previously owned; '30 Sport Coupe '28 left brake ccPickup '31 SW Town Sedan '28 AA Stake Bed '30 Cabriolet '42 Super Deluxe 4door Sedan "If it don't fit, get a bigger hammer. If it breaks...... ya needed a new one anyway!!" Doing a good job here is like wetting your pants in a dark suit. It gives you a warm feeling, but nobody notices. Never pass up a bathroom Never neglect an erection Never trust a fart |
12-15-2016, 10:59 AM | #4 |
Re: Valve springs
A vise and bathroom scales will give you pretty good ballpark figures.
12-15-2016, 11:26 AM | #5 |
Re: Valve springs
They are cheap... just replace them?
12-15-2016, 12:06 PM | #6 |
Re: Valve springs
All steel from pedal to wheel |
12-15-2016, 12:26 PM | #7 |
Re: Valve springs
As PC/SR says or a scale on your drill table and use the quill to compress the spring.
12-15-2016, 12:38 PM | #8 |
Re: Valve springs
According to Les's red book, the spec is 57-64 lbs at 2.250".
12-15-2016, 04:56 PM | #9 |
Re: Valve springs
When using the drill press, insert a used valve in the chuck for a flat surface to push against the spring. Use your depth stop to provide your spring height dimension. I've done thousands of springs that way. It's not hi-tech but it will get the job done.
12-15-2016, 05:22 PM | #10 |
Re: Valve springs
3.6 I don't think spending 277 dollars is what he had in mind for a shade tree job.
12-15-2016, 08:52 PM | #11 | |
Re: Valve springs
12-16-2016, 09:22 AM | #12 |
Re: Valve springs
Thanks for the "shade tree" solutions. appreciated. Jack
