Old 10-16-2019, 05:13 PM   #1
Conaway2
Conaway2's Avatar
Default USB charger socket for 6 V system
Is anyone aware of a USB charger socket that will work with a 6 V input from a stock Model A electrical system ? I did buy an inexpensive one, but it apparently needs more than 6 V to keep charging. Most of the time it just flickers on and off.
Conaway2 is offline   Reply With Quote
Old 10-16-2019, 05:23 PM   #2
jrelliott
jrelliott's Avatar
Default Re: USB charger socket for 6 V system
Did you get the polarity correct? If you are using a positive ground system, will have to isolate the charger socket as most require a negative ground.
jrelliott is offline   Reply With Quote
Old 10-16-2019, 05:38 PM   #3
Conaway2
Conaway2's Avatar
The polarity is correct. The socket I bought has a plastic body, so easy to isolate.
Old 10-16-2019, 05:55 PM   #4
eagle
eagle's Avatar
You may need a noise filter ahead of the charger. Model A electrical systems are too noisy for most modern electronics without some serious filtering first.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 10-16-2019, 06:27 PM   #5
Bill G
Bill G's Avatar
I bought a 6 to 12-volt inverter, fused it and mounted it under the car on the back side of the cross rail that is just behind the battery. From there, I ran two wires (neither can touch ground) up to the cab that terminates with one of the cigarette lighter style sockets that just about anything can plug into.
Bill G is offline   Reply With Quote
Old 10-16-2019, 07:24 PM   #6
Merc Cruzer
Merc Cruzer's Avatar
Read through this, it will hopefully answer your question and provide you with a solution:
https://www.fordbarn.com/forum/showt...ing+cell+phone
Merc Cruzer is offline   Reply With Quote
Old 10-16-2019, 10:20 PM   #7
Jim/GA
Jim/GA's Avatar
Just try a different little plug-in USB plug to put the charge cable into. I have found some that are more picky about their input voltage than others. From my limited trials, until I found one that worked, it was the cheaper units that were less concerned about the volts input; the more expensive units didn't like 6 volts. The GPS and cell phone charge on 5 volts, so they will work on 6.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 10-17-2019, 04:43 AM   #8
PRG999
I did the same as Magicbox51. I have the one that has multiple usb ports so I can run the Garmin and charge a phone with no issues.
PG
PRG999 is offline   Reply With Quote
Old 10-17-2019, 09:51 AM   #9
duke36
Ditto: and one can mount the angle bracket under the gas tank with professional grade 2 sided moulding tape
duke36 is offline   Reply With Quote
Old 10-17-2019, 10:07 AM   #10
The Master Cylinder
The Master Cylinder's Avatar
I can charge my iPhone OK but the 'Traffic' on my Garmin does not work on 6v. Probably has something to do with the charge cord is also the antenna for the Garmin Traffic?
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 10-17-2019, 10:56 AM   #11
Conaway2
Conaway2's Avatar
Thanks everyone - I’ve bought another inexpensive charger socket to try, and also have bought an inverter to boost input voltage to the charger socket to 12 V - if the second charger socket also doesn’t work. I do run a Fun Projects 6 V regulator on the generator - which works quite well - not sure if that would affect operation of the charger socket - which is connected directly to the battery and positive ground on the frame.
Old 10-17-2019, 01:39 PM   #12
ryanheacox
ryanheacox's Avatar
I made my own from some scavenged parts and a 5V regulator. Works great and it was a fun project. I sealed it all in a little box and mounted it on the firewall.
ryanheacox is offline   Reply With Quote
Old 10-17-2019, 07:12 PM   #13
CarlG
CarlG's Avatar
Or Velcro
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-20-2019, 11:17 AM   #14
Conaway2
Conaway2's Avatar
I just installed this USB charger socket from Amazon, and it works just fine on the stock 6 volt positive ground electrical System on my Model A. It even has an on/off switch.
【Upgraded Version】Car Charger with Switch, CHGeek 12V/24V 22W Waterproof 2.1A & 2.1A(4.2A)... https://www.amazon.com/dp/B07SGJ5DN4...sms_tai_4EiRDb...
