Old 03-23-2015, 10:42 PM   #1
steve hackel
steve hackel's Avatar
Default Ideal I.D. for a lifter bore?
I am cleaning up an older block and have a new set of adjustable lifters that I would like to use. The original solid lifters seem a "little" loose to me and the new adjustable lifters feel about the same. In an ideal world, what should the lifter to bore clearance be - what was a new blocks lifter bore I.D. and what should the lifters be now? Thanks,
steve hackel is offline   Reply With Quote
Old 03-23-2015, 11:38 PM   #2
PC/SR
Default Re: Ideal I.D. for a lifter bore?
Stock lifter bore was .5940-.5945. Snyders sells oversize lifters. You may get a difference of opinion on clearance. The stock lifter was .5925-.5935, so tolerance was .0005-.002.
PC/SR is offline   Reply With Quote
