Old 05-14-2018, 12:09 PM   #1
Dave Castle
Dave Castle's Avatar
Default 40/41 Pickup Fuel Tank ?
Anyone have a recommendation for a new 40/41 pickup fuel tank, the one from Drake was junk, its on its way back.
Dave Castle is offline   Reply With Quote
Old 05-14-2018, 12:10 PM   #2
Kube
Kube's Avatar
Default Re: 40/41 Pickup Fuel Tank ?
Dave, unfortunately I am unable to offer an alternative source.
Still, might you explain what the issue(s) was with the Drake tank?
Old 05-14-2018, 12:34 PM   #3
alanwoodieman
my experience with a drake purchased fuel tank was where the two pieces of the tank were welded together--there was about 1 to 1 1/2" of extra metal that had to be trimmed all around to get to the correct original size and the tank went right in. the owner of the truck worked for two days and was ready to send it back when he called me for help
Old 05-14-2018, 01:14 PM   #4
randy993
randy993's Avatar
I purchased one that's sold by Tanks Inc. I actually bought it on ebay. Went right in.
http://www.ebay.com/itm/1938-1939-19...0AAOSwAL9UjHLg
randy993 is offline   Reply With Quote
Old 05-14-2018, 02:04 PM   #5
Dave Castle
Issues with the tank were 3 of the 4 corners were bent & needed to be dollied flat & the drake sender would not line up correctly with the holes in the drake tank. And yes I know the sending unit only goes in one way. Also the mounting holes did not line up with the holes in the frame, total waste of my time.
Old 05-14-2018, 07:42 PM   #6
FHFD
FHFD's Avatar
I've used Tanks inc. with success.
"Get your facts first..then you can distort them as you please"
FHFD is offline   Reply With Quote
Old 05-14-2018, 09:10 PM   #7
51504bat
51504bat's Avatar
Used a Drake tank for my '39. Fit with no issues BUT my truck does have a Studebaker bed on it so its hard to say how it would have fit with a stock bed. I did buy it on one of his Black Friday sales with free shipping and amazingly it was in stock! Used a Drake sending unit and it fit fine.
Old 05-15-2018, 12:42 AM   #8
40larry
The passenger car and pickup gas tanks are not the same. The position of the inlet spout is different. Drake only sells the passenger car tank. You can use the passenger car tank by re-positioning the mounting holes on the frame so that the gas tank neck fits into the opening on the bed.
40larry
40larry is offline   Reply With Quote
Old 05-18-2018, 11:19 AM   #9
hotrodA
hotrodA's Avatar
^^^^Good info. Thanks, 40larry!^^^^
hotrodA is offline   Reply With Quote
