Old 08-29-2019, 12:47 PM   #21
19Fordy
19Fordy's Avatar
Default Re: Is this an ok radiator?
WABOOM: Too bad you can't send it back as not being made to OEM specs.
Old 08-29-2019, 01:20 PM   #22
leon bee
I guess on a $200 radiator my criteria would be, and was; Can I get it hooked up? Will it hold water? and Will it cool?
leon bee is online now   Reply With Quote
Old 08-29-2019, 01:26 PM   #23
WABOOM
WABOOM's Avatar
I did have to make an air dam. I made it out of angle iron. Here's a pic
WABOOM is offline   Reply With Quote
Old 08-29-2019, 01:31 PM   #24
drolston
drolston's Avatar
Originally Posted by drolston View Post
I put a Champion aluminum radiator in my '41. It fit perfectly and looks good. But I have had problems with overheating in traffic on hot days. Block was cleaned during overhaul. Timing is advanced. Changed to Dennis Carpenter water pumps which are supposed to flow better at idle; no noticeable improvement. Installed a spacer to get the fan closer to the radiator and put on a (partial) shroud; no help. Fabricated a baffle to keep air from going over the radiator; better on the road but not in traffic. Put in Subaru 170 degree thermostats, which open wider than stock units; no help.
The good news is that they are relatively cheap. Try the Champion and see how it works for your installation.
Update on my earlier post. Since then I scrapped the Champion and went to a four row brass/copper radiator, which works great under really stressful conditions of high heat and speed. I could never get the Champion to cool well enough on 90+ days. Tried every trick in the book (better pumps, water wetter, shroud, baffles, timing, richer mixture) but it still overheated badly at idle and at speeds over 60, on hot days. Also one of the mounting ears broke off.
It might work for you if your engine is stock and you don't get stuck in traffic or climb long hills on hot days.
Old 08-29-2019, 02:03 PM   #25
19Fordy
19Fordy's Avatar
WABOOM: Your angled piece looks great and will work fine. Good job. Keep us updated on how well the new radiator cools.
Old 08-29-2019, 02:15 PM   #26
bobH
I don't see that anyone has posted issues with electrolysis... I was losing radiators at the rate of about one per year in a 96 Bronco. Except towards the end of my aluminum experience, when the rate reduced to about one per 3 months. The Bronco went through a LOT of aluminum radiators. Then, I had a custom brass radiator made, and no more problems for several years now.
On the other hand, I have an aluminum radiator in another one of my vehicles, a cheapo from JEGS. It's been there for many years, and has never given any trouble.
bobH is offline   Reply With Quote
Old 08-29-2019, 02:31 PM   #27
19Fordy
19Fordy's Avatar
Use these strips to periodically check PH and then add suitable additives along with distilled water.
https://www.webstaurantstore.com/hyd...yABEgLkBfD_BwE
Old 08-29-2019, 02:35 PM   #28
WABOOM
WABOOM's Avatar
What ph is ideal?
Old 08-29-2019, 03:11 PM   #29
Charlie ny
WABOOM......Good luck , I'm sure glad you painted the rad. Lots of guys run alum but religiously keep an eye on the ph. Most use the orange anti freeze. Today's rads are
all alum with plastic tanks.
Charlie ny
Old 08-29-2019, 05:21 PM   #30
19Fordy
19Fordy's Avatar
Here's some Ph info..
https://community.cartalk.com/t/antifreeze-ph/55902
and
https://tomdwyer.com/2010/car-information/coolant-ph/
Some say you can check coolant Ph with a digital multimeter but,others say accuracy is debatable as a special multimeter is needed. Here's a video yo can try just for comparison.
https://www.youtube.com/watch?v=x-gceYx_3RE
I also add No-Rosion
https://www.norosion.com/tech_coolant.htm
Old 08-29-2019, 08:37 PM   #31
tubman
tubman's Avatar
Originally Posted by WABOOM View Post
What ph is ideal?
7 is neutral.
Old 08-29-2019, 08:37 PM   #32
tubman
tubman's Avatar
What ph is ideal?
7 is neutral. Not acidic or alkaline.
Old 08-30-2019, 10:02 AM   #33
WABOOM
WABOOM's Avatar
But do we know that 7 is the target ph for coolant?
Old 08-30-2019, 10:32 AM   #34
keith oh
keith oh's Avatar
As long as the ph stays 7.0, neurtal it can't react with anything. As soon as you add additives, unless they are neutral, things change. Nitrozene tape is the easiest and cheapest way to test fluids. Available at drug stores.
keith oh is offline   Reply With Quote
Old 08-30-2019, 10:45 AM   #35
keith oh
keith oh's Avatar
Hydrion ph test is the trade name for the ph tape
Old 08-30-2019, 10:46 AM   #36
rotorwrench
rotorwrench's Avatar
Aluminun used for structural applications is mostly 2024-T3 alloy but it doesn't weld well. The 1100 alloy is likely what is used to fabricate these since it is easily welded and it's mostly just aluminum. The magnesium aluminum alloys are better for welding but it takes some processes for normalization that would make it expensive to use for a radiator.
Structurally aluminum has to be pretty thick to form a good beefy structure to take vibrations well. There is also the corrosion factor. It should have coolant that will lessen the corrosion factor as is available for modern aluminum radiators. Aluminum radiators are a one shot deal. You can't easily disassemble one for cleaning or recore since they are not designed to do so. When they don't work you throw them in the recycle pile and buy another one.
The aluminum radiators don't cool any better than the old brass and copper units. They look funky and they don't always fit well. If a person doesn't mind all that then go for it.
JAMCO used to have a good product and they are relatively reasonable. The one I bought for my AV8 is real nice and it's the short 32 Ford type to fit the 32 grill shell on a 29 model A. You might think about that one for a Merc with flathead V8.
https://www.jamcosuspension.com/prod...productID/2449
