Old 09-13-2017, 12:53 PM   #1
James G.
Default stainless exhaust rattle continues - help!
I greatly appreciate the tech info on stainless expansion, but, how did you guys deal with hanging to stop/prevent the rattle? What worked for you? Pix would help.
Jim G.
James G. is offline   Reply With Quote
Old 09-13-2017, 01:07 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: stainless exhaust rattle continues - help!
Any chance it is inside the muffler?? Maybe loose baffles?
Just a thought, seems like hanger isn't the issue..........
Oldbluoval is offline   Reply With Quote
Old 09-13-2017, 07:39 PM   #3
James G.
Default I used the stainless muffler hanger from Breatton's but
The fabric liner only lasted a few months and the rattle came back. I tried wedging fiberglas around the pipe but that also failed. I am hoping someone has solved this problem and will share.
Jim G.
Old 09-14-2017, 11:24 AM   #4
duke36
Some folks use a modern tail pipe rubber insulated hanger (from any parts store) adapted with straps and/or flat metal formed to attach to the frame rail. check other posts. Also in one instance we found an exhaust port ring rattling in the muffler but that doesn't appear to be your issue.
duke36 is offline   Reply With Quote
