08-30-2012, 08:31 PM | #1 |
Emergency brake question please
Do the emergency brake band springs hook in the outer hole of the small clip on the band?
Thanks in advance. Charley |
08-30-2012, 08:50 PM | #2 |
Re: Emergency brake question please
Someone on the barn posted this pic (thanks) and I saved it. Hope this helps.
08-30-2012, 09:21 PM | #3 |
Perfect, Thanks
08-30-2012, 10:03 PM | #4 |
The part of the band where the links connect has a surface that rides on the emergency brake band carrier, so make sure the band is installed with the correct side facing the carrier.
08-31-2012, 07:37 PM | #5 |
Is there an easy way to install the dust cap over the adjusting wedge? What should wheel lug nuts be torqued at? Thanks and regards. Chaley |
