05-04-2019, 05:06 PM | #1 |
Lincoln V-12 Distributor Parts
Bought a couple small boxes of Flathead parts at a swap meet last week and have been going through them to decide what to discard. There was a very gummed up rotor shaft and weights that I took part and cleaned yesterday that turned out to work very nicely. I was going to use this setup in a distributor that needed a rebuild when I figured out it wouldn't fit, too long. Compared to another and figured out it was for Lincoln not Ford. Went through more parts and a few more popped up including an old condenser marked Zephyr as well as two new ones. Not sure about vacuum lines especially the one on the left. Don't have a use for these parts and looking at boos-herril.com am unsure of value if I sell them. Any input is appreciated. And yes the rotors are not for Lincoln.
05-04-2019, 09:29 PM | #2 |
Re: Lincoln V-12 Distributor Parts
Looks like Lincoln. Look on the tang end of the shaft and if it has an "H" stamped on it that would confirm Lincoln.
05-05-2019, 05:32 AM | #3 |
Has 46 H stamped on tang.
05-05-2019, 07:10 AM | #4 |
the condensers are most liklely no good. test them to be sure.
05-05-2019, 01:54 PM | #5 |
