Old 07-31-2011, 11:46 AM   #1
Joe AZ
Joe AZ's Avatar
Default Mechanical Temperature Gauges
I'd like to run two mechanical temperature gauges in my stock '40 Ford Coupe. I've got a couple of Stewart Warners' around I was going to use, but it's obvious that the coupling that is on the sensor end of the gauge will not fit the threaded openings in the heads. I've checked the local (good) hardware store, but have been able to come up with a fitting that will work.
Does anyone know if Stewart Warner has alternate fittings avaiable, or for that matter, what the size of the outlet in the heads is?
Thanks,
Joe
Joe AZ is offline   Reply With Quote
Old 07-31-2011, 12:11 PM   #2
lotsagas4u
Default Re: Mechanical Temperature Gauges
Check out this ebay auction #270738412601
I have these on my 8BA, They are 3/8 NPT
lotsagas4u is offline   Reply With Quote
Old 07-31-2011, 08:06 PM   #3
46fatford
46fatford's Avatar
I bought mine from my local parts store. Just went in and asked about adapters for mecahanical gauge sets that they sold. I think mine were about $5.00 a pr.
Matt
"..Nothin' outrun my V8 Ford" (Chuck Berry)
S.M.I.B.
46fatford is offline   Reply With Quote
Old 07-31-2011, 10:05 PM   #4
Joe AZ
Joe AZ's Avatar
Thanks for the information guys.......much appreciated.
Joe
Old 08-01-2011, 07:59 AM   #5
G.M.
Buy a laser pointed thermometer. One dash gage will tell you the total temperature in the engine and the gun will pinpoint temperatures on both sides and measure other temps like rear, trans, gen bearings, brakes and many other things. G.M.
www.fordcollector.com
Old 08-01-2011, 09:13 AM   #6
gmc1941
gmc1941's Avatar
Laser thermometer won't work on shiny objects. The laser beam bounces back. Perferrably black or dark green. Wrapping electrial tape acts as a insulator. My 3 cents... Gordon
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
Old 08-08-2011, 09:28 AM   #7
ole_Bill
ole_Bill's Avatar
I figure you probably got this solved by now, but I got my adapter from Speedway, P/N 1822372 and paid $7.99 - worked great.
"I ain't no mechanic, my posts should make that obvious, I'm jus doin my best with what I got."
ole_Bill is offline   Reply With Quote
Old 08-08-2011, 09:43 AM   #8
tdlmomowers
tdlmomowers's Avatar
NAPA sells adapters for Mech. Temp. gauges.
tdlmomowers is offline   Reply With Quote
Old 08-08-2011, 11:47 AM   #9
Joe AZ
Joe AZ's Avatar
Thanks guys.......I got what I needed at NAPA. I'm changing intakes and upper hoses, so I'll install the gauges when I do that work.
Joe
