Old 10-28-2021, 04:05 AM   #21
Ggmac
Default Re: Flat spot that just won't go away
Where do you live ? Sorry if I missed it in the post . At what rpm is your flat spot ?
Ggmac is offline   Reply With Quote
Old 10-28-2021, 03:01 PM   #22
FlatheadTed
FlatheadTed's Avatar
Check the Valve timing ,? remove the manifold to sight the valves at same time check the gasket ,use the Zip tie method or a wire to find TDC ,does it smooth out with the Choke out as 51 Merc suggested,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 10-28-2021, 04:49 PM   #23
Ross F-1
Ross F-1's Avatar
Maybe I missed it, but did you verify the advance mechanism is working?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-30-2021, 11:35 PM   #24
Speedbump47
Did have distributor apart to clean and check. All seemed good.
Will try what Flathead Ted suggests and report back.
Thanks Mike
Speedbump47 is offline   Reply With Quote
Old 12-15-2021, 07:40 PM   #25
Speedbump47
G'day all
Update...
Put on new carb and new e-fire distributor.
NO CHANGE!
Still have only 11 to 12 vacuum at idle. Does swing a little between 11 and 13
Comments have indicated valve timing could be the problem.
Are there any other suggestions before I start tearing the engine apart.
Thanks
Old 12-15-2021, 08:08 PM   #26
Bill OH
I would remove the intake manifold, turn it upside down and pour gasoline in the heat riser until the riser is full. Watch that gasoline level to see if it falls away however slight. You are looking for a cracked intake manifold in its heat riser. 11 inches of vacuum sure indicates a leak - should be around 18 inches with a stock cam. Using gasoline instead of water - gasoline will flow thru a crack much easier. Give it a try!
Bill OH is offline   Reply With Quote
Old 12-15-2021, 08:10 PM   #27
Crankster
Crankster's Avatar
I don't speak Flathead, but with an OHV engine there are simple "non-invasive" methods of checking valve timing. I'd expect there are ways on a Flathead, too. Incorrect (late) valve timing will definitely cause low manifold vacuum.
Crankster is offline   Reply With Quote
Old 12-16-2021, 02:56 PM   #28
Ross F-1
Ross F-1's Avatar
A real longshot, but there was a gorgeous yellow 48 Merc convertible in a shop here I visited. It had similar issues including the low vacuum. The mechanic pulled the intake and found someone had cracked off the edge of one cylinder's intake port, presumably while taking out valves. The intake had nothing to seat against there, so it leaked. Wondering if the car's owner had it buttoned up and sold it as-is, vs an expensive repair...
