Old 02-28-2021, 06:26 PM   #1
Marcus
Marcus's Avatar
Default Battery Comment - Not What You Think!
Remember when your mentor (Dad, Uncle, Cousin, whomever) told you to ALWAYS use two wrenches when loosening and/or tightening the battery cables to the terminals, or you risk breakng the battery terminal away from the battery? Well, I didn't and I did: thank goodness it was a 12 year old Optima, and I have a "hot" spare. But still.......listening, JWL?? I won't do that again!!
WARM REGARDS, MARCUS
Marcus is offline   Reply With Quote
Old 02-28-2021, 07:22 PM   #2
Mart
Mart's Avatar
Default Re: Battery Comment - Not What You Think!
Doh!
Old 02-28-2021, 08:35 PM   #3
paul2748
paul2748's Avatar
Never used two wrenches in loosening or tightening the cables to the battery. never had a problem either. They certainly do not need to be that tight
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 02-28-2021, 09:31 PM   #4
50fordcoupeman
50fordcoupeman's Avatar
While growing up on the farm, that our instructions also!!
50fordcoupeman is offline   Reply With Quote
Old 02-28-2021, 09:41 PM   #5
WABOOM
WABOOM's Avatar
I was taught to put the clamp on about 3/4 of the way down and the hammer it down the rest of the way. (I don't do it like that)
WABOOM is offline   Reply With Quote
Old 02-28-2021, 09:46 PM   #6
Lawson Cox
Lawson Cox's Avatar
Most of the cables have a flat where the head of the bolt goes, to keep the bolt from turning, and you can't get a wrench on it. My 2¢.
Old 02-28-2021, 10:09 PM   #7
mfirth
Also, NEVER let your wrench touch the other post.....when you're hot ; you're hot....put a nice mark on my ring finger & pited my wedding band....talk about DUH.
mfirth is offline   Reply With Quote
Old 02-28-2021, 10:23 PM   #8
Craig CT
Craig CT's Avatar
Hello Marcus; So this is actually a post about a post. Very clever. I hope you and the Mrs. are well, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 02-28-2021, 10:53 PM   #9
cmbrucew
cmbrucew's Avatar
Marcus
If the battery is new/good/expensive, take it to a battery shop that remanufactors or builds them, the post can be repoured.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-01-2021, 12:47 AM   #10
JWL
Yes, I understand and am paying attention.
JWL
JWL is offline   Reply With Quote
Old 03-01-2021, 07:29 AM   #11
Ford Freak
[QUOTE=paul2748;1990668]Never used two wrenches in loosening or tightening the cables to the battery. never had a problem either. They certainly do not need to be that tight[/QUOTE
x2!!
1952 Ford F1
1965 Ford Falcon Sprint
2007 Ford Mustang GT
Ford Freak is offline   Reply With Quote
Old 03-01-2021, 07:48 AM   #12
Mart
Mart's Avatar
Learnt the hard way as a snotty nosed kid not to tap them in place with a hammer. The post went inside the battery.
Old 03-01-2021, 08:23 AM   #13
40cpe
40cpe's Avatar
As others have noted above, it doesn't need to be really tight. I also hold the cable up close to the post in the opposite direction of the wrench force to support the post.
