02-20-2023, 07:13 PM | #21 | |
Re: Chevrolet Distributor
Ported vacuum is sourced from an opening that is situated just above where the throttle plates are situated at idle, so there is no vacuum advance until the throttle plates are opened slightly. When you "jack up the initial timing", you are also adding to the total timing so you may be over advanced at high RPM which can lead to detonation which can lead to damage even if you can't hear it! Use a timing light. ! |
02-20-2023, 09:18 PM | #22 |
All is not clear to me, you will have to explain your position which I deem wrong. I stand completely behind my post above. (This is in response to post #20). 40 DeLuxe has it right.
02-21-2023, 08:46 AM | #23 |
In cruise you have max Vacuum advance. When you goWOT you loose the advance. Kinda nice, don't ya think???
02-21-2023, 10:01 AM | #24 |
In a closed throttle position the manifold vacuum is high resulting in the maximum advance of the can. When you open the throttle plates that vacuum is lessened essentially SUBTRACTING advance.
02-21-2023, 10:20 AM | #25 | |
My "jacked up" comment was to prove a point, our flatties like a lot more advance at an idle. I posted the timing I use at the beginning of the thread. Without knowing true TDC AND verifying the timing curve in your distributor a timing light is a feel-good device demonstrating a “ball park” setting. |
02-21-2023, 10:35 AM | #26 |
02-21-2023, 11:22 AM | #27 |
I had a converted SBC distributor with vacuum from the best source on my "Hot Rod" engine. It ran fine, but I decided that I wanted a "flattop" Mallory, mainly to provide a complete "old-timey" look. To my surprise, it ran as good, if not better with the Mallory than the conversion unit.
02-21-2023, 12:20 PM | #28 | |
Of course we need to be "knowing true TDC and be verifying the timing curve in your distributor"! That goes without saying. It gives us a reference, a starting point, in making adjustments. Setting the timing by ear or by using a vacuum gauge is truly the "feel-good" method for getting in the "ball park" (maybe, but more likely missing the ball park!). |
