Old 04-03-2011, 11:37 AM   #1
Digger
Digger's Avatar
Default a '32 Five Window pics
I picked this up a few weeks ago, thought I would share pics and info. Car was a stocker in OR a few decades ago, then was in SoCal in the Ross Racing Pistons collection.
Has a '36 motor and trans, came with a mint early Thickstun intake with two restored large logo 97's, but I have not yet installed it. Metal is very good, also came with the original fenders, running boards, headlights, frame covers that were simply taken off the stocker and stored away. Has '40 rear end, juice brakes, dual Smittys, and great for just driving around town. I have done highway driving, but not freeway driving, too many nuts on the road.
One question regarding speedo, it is the original, but the previous owner said something about since it is a '40 rear end, the numbers on the odo were going backwards when he connected the cable...? Any info on getting it working right would be appreciated. Thanks Barners
Digger is offline   Reply With Quote
Old 04-03-2011, 02:04 PM   #2
WHITEY
WHITEY's Avatar
Default Re: a '32 Five Window pics
I reeeeeeeeeeely dont like you right now...
That IS perfection...
Timeless.
WHITEY is offline   Reply With Quote
Old 04-03-2011, 02:08 PM   #3
JeffreyJames
JeffreyJames's Avatar
21 stud with a Thickstun and some 97's is just icing on the cake. That thing is beautiful and so is the one in your avatar.
JeffreyJames is offline   Reply With Quote
Old 04-03-2011, 02:40 PM   #4
Flathead Fever
Flathead Fever's Avatar
That is a beautiful 5-Window. This car proves you don't have to butcher an early Ford to build the perfect hot rod.
Flathead Fever is offline   Reply With Quote
Old 04-03-2011, 03:43 PM   #5
Digger
Digger's Avatar
How can I get a little more speed out of it? Will the Thickstun help with HP? I do have perfectly running stock 59ab to put into it, how much will that help? I am not into the frame twisting type motors, just something to get me at 65-70 mph on the freeway....
Old 04-03-2011, 04:07 PM   #6
Lawson Cox
Lawson Cox's Avatar
Super nice looking rod. I have never heard of a speedometer running backwards like that. Have you checked it out yourself?
Old 04-03-2011, 04:16 PM   #7
Mart
Mart's Avatar
Nice 5- window - one of my favourites, but sadly out of my reach.
Not sure about the speedo, can't give a definitive answer, but if the turtle on the torque tobe has been fitted backwards, that would make the cable run backwards.
If it were me I would disconnect the speedo cable at the speedo, and watch which way it rotates as I drive along. You have to imagine which way it would be rotating as it enters the back of the speedo. If it is rotating clockwise (the right direction for the speedo to gain mph) as you look on the end of it, it is correct, if it rotates anti-clockwise then the turtle fitting (speedo takeoff) has been fitted backwards on the torque tube.
As it went wrong when he fitted the 40 axle my guess is that this is the problem.
Mart.
Mart is online now   Reply With Quote
Old 04-03-2011, 05:28 PM   #8
35cab
35cab's Avatar
I had same problem, just turned the speedo drive turtle round, as Mart said.
Great looking car, really perfect in fact, everyone likes roadsters, three windows, etc but I think the 5 window is a really well designed and proportioned car.
35cab is offline   Reply With Quote
Old 04-03-2011, 09:57 PM   #9
Digger
Digger's Avatar
thanks for the comments on the car. I have not yet messed with the speedo but will take up these suggestions and post results. thanks
Old 04-03-2011, 10:37 PM   #10
Mike in AZ
Mike in AZ's Avatar
very nice looking car....I think you'll need new gears in the rear end to get more highway speed....have fun driving that beauty....Mike
Mike in AZ is offline   Reply With Quote
Old 04-04-2011, 10:49 AM   #11
Byron Warwick
Byron Warwick's Avatar
I had the same experience when I put Merlot back on the road. I noticed that the miles were coming off the odometer. Reversed the turtle and am puttin' the miles on the right way. I drove 2000+ miles each of the past 2 years. Byron.
IT'S NOT YOUR AGE, IT'S YOUR ATTITUDE !
Byron Warwick is offline   Reply With Quote
Old 04-04-2011, 04:28 PM   #12
jimTN
Check rear end ratio. I have a 9/37(3:78) and large diameter Goodrich 18" rubber on my 32 with a stock 34 85 and can run 55-60 mph on the interstate with no problems. Looks like you may have 16" rubber on yours, that will slow you down a little and make it steer harder. My car had 16" rubber on it when I bought it and I changed it back to the correct 18"s.
jimTN is offline   Reply With Quote
Old 04-04-2011, 07:43 PM   #13
denson1932
denson1932's Avatar
Oops if you divide 9 into 37 you get 4.11 which is the typical stock 1932 Ford ratio no matter if early Model A style or later V-8 style. Most are the early style so buy yourself a set of 3.54 gears from Mac,s or Drake or Dick Spadaro Parts.
denson1932 is offline   Reply With Quote
Old 04-05-2011, 09:08 AM   #14
FOMOCOHOLIC
FOMOCOHOLIC's Avatar
That in my eyes is perfect.
FOMOCOHOLIC is offline   Reply With Quote
Old 04-05-2011, 03:52 PM   #15
evans32
evans32's Avatar
Perfect car! I just installed a set of 3:54's in my roadster and it really makes a great freeway driver.
evans32 is offline   Reply With Quote
Old 04-05-2011, 06:40 PM   #16
cadillacoffin
this fellow is running a 21 stud engine in his 32 truck. thought you might like to read about it.
http://www.jalopyjournal.com/forum/s...ighlight=truck
http://www.jalopyjournal.com/forum/s...d.php?t=514375
http://www.jalopyjournal.com/forum/s...d.php?t=504353
cadillacoffin is offline   Reply With Quote
Old 04-05-2011, 10:07 PM   #17
Digger
Digger's Avatar
excellent, thanks Barners,
looking for pair of orig 33 bumpers....
