Old 01-16-2018, 10:44 AM   #1
fortyman
Default 1940 steering box housing end plate
The tube on my housing end plate is broken. Can it be repaired or where can I find another.
fortyman is offline   Reply With Quote
Old 01-16-2018, 11:07 AM   #2
GaryU.
GaryU.'s Avatar
Default Re: 1940 steering box housing end plate
I've got two extras at home, will post photos later to verify they are correct. Came with some other parts. Maybe yours can be repaired also, others will chime in I'm sure.
GaryU. is offline   Reply With Quote
Old 01-16-2018, 11:14 AM   #3
JSeery
JSeery's Avatar
One method of repair would involve silver soldering the tube back to the end plate.
Old 01-16-2018, 12:12 PM   #4
Kube
Kube's Avatar
This is the method I have used...
Old 01-16-2018, 06:19 PM   #5
GaryU.
GaryU.'s Avatar
Here's some pics of steering box end plate and tube. My 39 pickup had a brass tube attached to plate and I did have to repair it because it was cracked at plate. The extras I have are different with a steel tube and seem to be smaller in diameter than the brass one if my memory is correct. Hope someone can confirm a change occurred when the horn rod was eliminated as the extras were with a steering box marked 41 Mercury.
Old 01-17-2018, 10:08 AM   #6
fortyman
That is what I need. How can I go about getting from you?
Old 01-17-2018, 10:50 AM   #7
GaryU.
GaryU.'s Avatar
Fourtyman sent you a P.M.
Old 01-17-2018, 12:01 PM   #8
fortyman
Responded to your PM
