06-05-2016, 07:33 PM | #1 |
Main drive gear
Don't beat up too bad but I need the best coverage on this...........
Does anyone have or know of an available 17 tooth main drive gear for the T 85 BW 3 spd trans ? This gear has the 1 1/16 10 spline and is 40% bigger than the '49-'56 Ford/Merc part. This type trans was used in big block Ford, Buicks, Olds, Packards etc in the mid 50's to mid 60's. Gracias, Charlie ny |
06-06-2016, 08:57 AM | #2 |
Re: Main drive gear
I've seen them on flea-pay but not for a while. The 17-tooth was the first of the "diamond cut" type gears starting in 1951. A lot of the trucks should have had this transmission after 1951. Maybe Mac VanPelt has one.
06-06-2016, 12:38 PM | #3 |
Re: Main drive gear
Do you have a part number for that gear? I have a fair selection of NOS gears at the moment. Either the Ford number or one of the other common numbers like Perfection, Lempco or Republic.
06-06-2016, 05:26 PM | #4 |
Re: Main drive gear
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
