05-30-2013, 06:23 AM | #1 |
Oil change
I am planning on draining the oil on my car this weekend.
* Do I just remove the drain plug and empty the pan? * Is there a screen or filter of some sort? * What oil is recommended? * How may quarts of oil are needed? Sorry for the basic questions, I am still learning the vehicle. Thanks Mike |
05-30-2013, 07:02 AM | #2 |
Re: Oil change
5 quarts non-detergent just remove the plug and drain it. lefty loosy righty tighty
1928 "A" Phaeton (mid year with many early features) 1933 "V8" Closed-Cab Pickup Truck (originally a Model B, 4 Cylinder dating to May, 1933)
05-30-2013, 11:46 AM | #3 |
Re: Oil change
Wrong!
http://www.model-a-ford-4bangers.com/ |
05-30-2013, 07:03 AM | #4 |
Re: Oil change
Yes, install 4 1/2 quarts of YOUR choice oil. Many different views on what type/brand to use. I use 30W. Do a search at top of page. Also suggest you get a copy of Les Andrew's book Vol 1, available from any of the vendor's and possibly amazon. Lots of good info. Al;so get some free catalogs from the vendors, there's a wealth of info in them also.
Paul in CT |
05-30-2013, 07:19 AM | #5 |
Re: Oil change
A new engine takes 5 quarts but a half quart is retained in various places in the motor so it will take 4 1/2 on a refill. Also the change frequency is 500 miles because there is no filter and a few other reasons. It is just as important to lube the cars lube points properly and on a set schedule. Here is that info...
I got the lube chart from an owners manual that can be found here. http://www.motormayhem.net/mode-a-fo...owners-manual/
Wanted: Simmons Super Power Head Craig Likon 1931 150B |
05-30-2013, 08:33 AM | #6 |
Re: Oil change
V4f |
05-30-2013, 09:13 AM | #7 |
Re: Oil change
Mike,
Good questions... especially if you have never changed the oil in your car. I received the following advice when I did my first oil change about 1.5 years ago. If this is the first oil change on a "new to you" car, be certain to look at how opaque or transparent the oil is that drains. If it looks like chocolate syrup or is really gritty, it may be time to consider "dropping the pan" and cleaning out the valve chamber. If the oil looks like light or dark maple syrup, you are in good shape -- change it regularly and enjoy. If it looks milky, that is a different can of worms completely as you have water or coolant getting in there. If it has pieces of metal in it, call a mechanic! |
05-30-2013, 09:21 AM | #8 |
Re: Oil change
Should also note that when you loosen and take out the plug in the pan make sure you grab the small ring/washer that comes with it and don't allow it to fall into the oil catch bucket...done that and isn't fun. Also when tightening the plug don't over do it and strip the threads. If it's an older engine I run Shell Rotella 15W-40.
_________________________________________ 1931 Ford Model A Tudor 1930 Ford Model A Deluxe Roadster 1930 Ford Original Rolling Chassis- Restoring |
05-30-2013, 04:06 PM | #9 | |
Re: Oil change
yea, I have had that happen to me a few times over the years. Thanks Mike |
05-30-2013, 09:26 AM | #10 |
Re: Oil change
If you can, find out what the previous owner was using for oil, that will tell you a lot.
05-30-2013, 04:09 PM | #11 | |
Re: Oil change
Thanks Mike |
05-30-2013, 04:51 PM | #12 |
Re: Oil change
Msaby,
I would urge you to get the Model A owners manual and other Model A books and THEN ask for help on the Barn. In that manner, you can compare the answers.... Marc |
05-30-2013, 07:49 PM | #13 | |
Re: Oil change
I will keep my questions on this forum at a minumum. Sorry for posting such basic questions . Thanks Mike |
05-31-2013, 06:10 PM | #14 | |
Re: Oil change
Dog here, you DON"T have to minimumize your questions here, jist "FIRE" away Iffin' you encounter a coupla' GROUCHES here, jist "BLOW" them off! I know Model A stuff, too, so if you want to by-pass Ol' Bill, jest ask me. You gotta' Dog? Me, I'm a Rat Terrier Show Dog I KILL rats & other RODENTS & even SNAKES! (I'm for hire, also $$$$) Buster T.
05-30-2013, 09:48 AM | #15 |
Re: Oil change
As you can tell equals liters? "install 4 1/2 quarts"
"Los hombres cobardes ven la muerte muchas veces, los hombres valientes solo una" "Siempre hay que tratar de ser el mejor, pero nunca creerse el mejor". J.M. FANGIO |
06-03-2013, 03:41 PM | #16 |
Re: Oil change
05-30-2013, 11:01 AM | #17 |
Re: Oil change
I like the Delo 400 as it is a 15-40 weight and has some zinc in it as it was formulated for diesels.. Just remember, *any* oil is better than none at all
- Dave in Boise |
04-23-2017, 01:23 AM | #18 |
Re: Oil change
If it's dello le, then it does not have zinc. I don't think you can buy the old dello anymore. Thanks
05-30-2013, 11:49 AM | #19 |
Re: Oil change
Just drain the oil and replace it with enough to bring the level to half way between the F and the L. You may find it will only take 4 quarts to get to that point. Use any Diesel grade HD oil or if you don't want to use Diesel oil any kind of High Detergent is good. Non detergent oil is for lawnmowers and I don't even use it in mine.
05-30-2013, 12:09 PM | #20 |
Re: Oil change
Warm the engine up first , it will flow out better .
