07-17-2015, 05:01 PM | #1 |
compression
Should Snyders 5.5:1 Model A head have more Compression then a regular head. Mine is 60 60 60 55 Thanks John
07-17-2015, 11:17 PM | #2 |
Re: compression
yes
07-17-2015, 11:23 PM | #3 |
Re: compression
John,
Cranking cylinder pressure is not really relative to C/R. So many factors combine to the cranking pressure that it is only a comparison from cyl to cyl. Adding compression, or increasing the C/R is going to add performance. At some point, the increase can be detrimental, ask around here, but be honest. The condition of the base motor and the intended use are instrumental to success. If the rings are worn, bearings/Babbitt is questionable then adding compression is just likely to finish off the motor sooner. John
As Carroll Smith wrote; All Failures are Human in Origin. |
07-17-2015, 11:31 PM | #4 |
Re: compression
try a different compression gauge, I have seen a lot of variations, ones with long rubber hoses tend ot read lower because the hose swells
07-18-2015, 05:53 AM | #5 |
Re: compression
Make sure the throttle is wide open and all plugs removed. Ron W
07-18-2015, 07:09 AM | #6 |
Re: compression
Bob Bidonde |
07-18-2015, 10:58 AM | #7 |
Re: compression
Bob is dead on right. I have two As. One with a Snyder 5.5:1 and one stock. The stock reads 60psi and the 5.5:1 reads 60
07-18-2015, 11:00 AM | #8 |
Re: compression
Misprint 5.5 reads 90
07-18-2015, 11:25 AM | #9 |
Re: compression
Compression test:
Engine warm & just ran. FULLY charged battery. Crank it at least 10 strokes or until the gauge quits rising. AND, remember that ALL gauges don't read the same! Bill W.
07-18-2015, 04:33 PM | #10 |
Re: compression
How can I identify a 5.5: 1 Snyder's head on an engine I bought that was sold as having a Snyder's head? Thanks, John
07-18-2015, 06:04 PM | #11 |
Re: compression
Mine is a stock head. Two compression gauges.... One says 50# all across, The other says 70# all across. It appears the average should be OK! Darned gauges, probably a third would be even different.
07-18-2015, 06:05 PM | #12 |
Re: compression
Get a snap on and it will read accurately
07-19-2015, 08:34 AM | #13 |
Re: compression
Are we just trying to get HIGHER READINGS for BRAGGIN' RIGHTS?? If it runs well, JUST DRIVE IT!!!
Bill W.
07-19-2015, 09:32 AM | #14 |
Re: compression
Bill. If it was running right I would not be asking these questions John
07-19-2015, 09:41 AM | #15 | |
Re: compression
Bill W.
07-19-2015, 10:02 AM | #16 |
Re: compression
My Snyders 5.5 head has a small circle with 5 dots in the casting on the left side, the 6 to 1 has 6 dots.
Nothing can be made foolproof, ---- fools are ingenious bastards. |
07-19-2015, 11:17 AM | #17 |
Re: compression
Brian My Synder head has 2 small circles with 5 dots in each circle on the driver side Thanks John
07-19-2015, 02:58 PM | #18 | |
Re: compression
I guess if I'm THAT low, I could use a heavier oil or an old-engine additive. Thanx fer the good tips. Chuck
... prosperity is not the product of charity but of industry - HENRY FORD |
