Old 11-20-2019, 10:17 AM   #1
Werner
Werner's Avatar
Default Clutch restauration, some questions
Hello and good day each other.
I have 4 questions about the restoration of the clutch.
1) The pressure plate was already turned off and honed early lathe. Does anyone know the given minimum / wear measure (thicknes)?
I measure 14.1 mm.
2) How thick is the pressure disc plate new?
3) In the pressure plate mechanic I discover different compression springs: red, green, brown; shorter and longer.
Does the color coding have a meaning (spring tension)?
What is the correct spring length? I measure 56 mm and 51 mm.
4) Under the compression springs in the little pans are round inserts made of plastic. They are very hard and brittle. Is that correct?
I thank you in advance!
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 11-21-2019, 03:07 AM   #2
Werner
Werner's Avatar
Default Re: Clutch restauration, some questions
Hello nobody here who knows the thickness of the pressure plate and the length of the springs?
Werner
Citroen 11 CV, 1947
Old 11-21-2019, 06:57 AM   #3
ryanheacox
ryanheacox's Avatar
Never had one apart. I can’t offer much advice other than have you searched here for past posts on the subject?
ryanheacox is offline   Reply With Quote
Old 11-21-2019, 07:15 AM   #4
History
History's Avatar
Wish I could help. Surely someone will be along soon who knows these well.
History is offline   Reply With Quote
Old 11-21-2019, 08:48 AM   #5
mike657894
mike657894's Avatar
when i had mine apart the fingers were pretty worn and the fly wheel was very cracked on the surface. the old style clutch plate looked like new. I let it be. And adjusted it and run it. Sounds like you need a new pressure plate. the machineing to the one you have was probably a stop gap when replacement was no available.
https://www.macsautoparts.com/ford_m...E&gclsrc=aw.ds
mike657894 is offline   Reply With Quote
Old 11-21-2019, 09:12 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
i have a book---clutches,transmissions from ford printed in 1947
.015 max clearance between drive lug and plate (on last page it gives .005-.015)
on the last page, specifications page --spring pressure at 1-9/16
grey---115-120 lbs ---11" clutch
blue 125-135 ---10' clutch
brown 147-153 9" clutch
then back in the text it gives-- spring load (pound feet) ---i
B-7563 110-120
BB-7563-B 110-130
74-7563 (this is 60hp, it's built about the same) 135-140
there is no mention of distance
if the plate itself won't clean up of .031 from original size replace it (no mention of original size), thought there is a note---if refaces over .020 add shims of the same amount under spring seat
set fingers at 3/4", .340 spacer or new clutch disc
For the A I am still using the one that came with the car untouched, on the Traction I made the springs into groups that balanced the pressure, made insulating washers out of surplus epoxy circuit boards (I was getting paid to peel the gold off) ---here traction parts are hard to get
Old 11-22-2019, 02:41 PM   #7
Werner
Werner's Avatar
Hello everybody,
today I received nice parts from Bratton's. Also the clutch friction disk. But I have just seen that that is 'Made in China'.
I am sceptical.
Does anyone have experience with this component?
Thanks for good hints! ---
Guten Abend Kurt, thank you so much for your helpin' large listing for clutch-springs!
Werner
Citroen 11 CV, 1947
Old 11-22-2019, 03:22 PM   #8
chrs1961815
chrs1961815's Avatar
The one on the left is a good one because it has reinforcing tangs to keep the springs secure. I have one on my car.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 11-22-2019, 03:37 PM   #9
The Master Cylinder
The Master Cylinder's Avatar
The disc from Bratton's is the one I use. It has the tabs that retain the springs. The disc other vendors sell don't have the tabs.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 11-25-2019, 02:36 PM   #10
Werner
Werner's Avatar
Probably I have misunderstood something: The hardest of the 5 different pressure springs has a length of 2.3 inches. When I press these together on 1 9/16" like described above, I measure a pressure of 85 lbs.
Werner
Citroen 11 CV, 1947
Old 11-25-2019, 04:56 PM   #11
Russ/40
Russ/40's Avatar
Werner, I think your putting your energy where your likely to end up with trouble. That is one assembly, that in my opinion is better left with the manufacturer. I would never attempt to rebuild a pressure plate or disc.
Russ/40 is offline   Reply With Quote
Old 11-25-2019, 05:05 PM   #12
Synchro909
Synchro909's Avatar
If they are built, they can be rebuilt. It might take equipment knowledge and patience that not all of us have but they are rebuilt everyday for trucks etc.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 11-25-2019, 05:36 PM   #13
Werner
Werner's Avatar
Russ, what you say is right. But I have to look at it from the other side of the globe. When I buy a restored pressure plate in the USA, I have to return the old one. Overall, the cost of duty + 2 X freight is painfully high.
I do not want to include a reproduction from China.
Therefore, I try to restore the existing pressure plate.
Werner
Citroen 11 CV, 1947
Old 11-25-2019, 09:34 PM   #14
1930artdeco
1930artdeco's Avatar
Werner,
If I can find the emails I can put you in contact with a spring manufacturer in Kentucky that makes the correct length and compression springs (pressure wise). If you want just shoot me a PM.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 11-25-2019, 09:50 PM   #15
F.M.
Why not just pay the Core Fee ??..
F.M. is offline   Reply With Quote
Old 11-25-2019, 11:45 PM   #16
J Franklin
J Franklin's Avatar
In your country there must be a shop that repairs clutches. It is hard to believe there is not one.
Old 11-26-2019, 01:15 AM   #17
Russ/40
Russ/40's Avatar
Werner, the company I buy my clutch packages from don't need your core. Fort Wayne Clutch. Maybe I can help you. If you do buy from the US, and need a core pressure plate, I could send one for you perhaps. I have one I will never use.
Old 11-26-2019, 04:30 AM   #18
Werner
Werner's Avatar
Good morning,
I think I can restore the clutch cage by myself. The pressure plate I can extern turn off at 1/128 ". I can round off the scoring finger levers myself. I have the finger-gauge and a dial gauge, also, I can measure the compressive force of the pressure springs.
It is not a big problem to buy suitable pressure springs here. But my problem is that I do not know which spring is the right one, because the built-out have five different dimensiones!
It is not certain, but as the balancing holes look like, the clutch plate could have been balanced as a group.
Werner
Citroen 11 CV, 1947
Old 11-26-2019, 01:16 PM   #19
J Franklin
J Franklin's Avatar
Since it is a hobby it is good that you like to do your own work. I try to do everything I can by myself and only send out work I know I can not do. You are an inspiration to many I hope. Thank you.
Old 12-19-2019, 01:52 PM   #20
Werner
Werner's Avatar
Hallo und guten Abend!
The fineley gound clutch pressuere plate is just being revised. I found now suitable industrial springs. All movable joints have been coated with PTFE sliding varnish.
The assembly is a 96 parts puzzle game for four hands!
Werner
Citroen 11 CV, 1947
