06-26-2019, 04:59 PM | #1 |
Coil
Should both screw terminals on the coil show voltage when ignition switch is on?
Thanks Dick |
06-26-2019, 05:14 PM | #2 |
Re: Coil
Dick, one clamp always shows constant current / voltage. The other terminal depends on whether the breaker contact is open or closed.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
06-26-2019, 05:54 PM | #3 |
Re: Coil
Thanks Werner makes sense if I'd stopped to think about it.
06-26-2019, 06:13 PM | #4 |
Re: Coil
