Old 09-01-2018, 05:28 AM   #1
Bruce of MN
Bruce of MN's Avatar
Default Timing with 6.0 Head
I searched "6 head timing" and found these:
https://www.fordbarn.com/forum/showp...3&postcount=15
https://www.fordbarn.com/forum/showp...71&postcount=2
Not exactly conclusive. I looked in Les Andrews, Vol. II, but no info there.
Any suggestions if I need to time the stock dizzy any different than for a stock head? I probably will have to use the lever more diligently.
Old 09-01-2018, 06:16 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Timing with 6.0 Head
Time the distributor for top dead center no matter which head is used.
More compression takes less advance of the spark lever.
Old 09-01-2018, 07:48 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
I start by timing at standard way, zero advance @ TDC. From zero advance @ TDC timing, I drive and iterate the advance to find the sweet spot with the lever all the down. This is done by tweaking the distributor cam.
Bob Bidonde
Old 09-01-2018, 09:31 AM   #4
duke36
Tom and Bob are right on in my experience. Yes, have found the advance more sensitive and less movement of the lever downward especially on hills. Some posts say to adjust the point setting also, but .020 has been fine so far with W18 plugs ...
Old 09-01-2018, 10:54 AM   #5
Patrick L.
Patrick L.'s Avatar
Both point and timing I think should be set as normal [ TDC & .020"].
I don't think these monsters need 40º of total advance with any cylinder head. I think 30º is plenty, so you could find that with the lever and either normally set the lever there or restrict the lever travel to that amount. I wouldn't want the base timing to be retarded much more than TDC.
Old 09-01-2018, 05:28 PM   #6
old31
With my 6.0 head I use .020 and W18 plugs. Most of the time the lever is between 3 and 4 oclock when driving. When climbing a hill the engine will tell me how much to back off the timing.
On a very flat road while doing 60 mph the lever will be at maxed at 4 oclock.
old31 is offline   Reply With Quote
Old 09-02-2018, 01:33 AM   #7
PC/SR
As you drive with the head you will start to learn how to use the spark advance. Not to much advance for cruising(say 25* for starters.). Full retard going down hills. A little less advance from cruise going up hills. As you (or anyone with any head) work with the spark you will become a better driver. I have gone to an FSI electronic distributor, which is strictly RPM controlled for the advance, and while I generally like it (and I have modified the spark curve) I do miss the close control of the manual advance.
PC/SR is offline   Reply With Quote
Old 09-02-2018, 09:18 AM   #8
old31
I had a FSI Zipper and returned it. It was just not a good product with the 6.1 head.
Old 09-02-2018, 12:15 PM   #9
Jerry in Shasta
Jerry in Shasta's Avatar
Remember 6.-1 may be high for a Model A, but by today standards it is very low.
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 09-02-2018, 01:08 PM   #10
wmws
I set my timing so with the lever all the way down I am at 30* BTDC. That way I know exactly how much advance I am giving it and don't have to guess with the lever.
wmws is offline   Reply With Quote
Old 09-02-2018, 01:42 PM   #11
duke36
Same with me, prior owner installed it.. Couldn't get timing retarded enough on hills without modifying the plate, advance springs, etc.
Thought the distributor body notch was supposed to allow for 20 degrees or about 1" wide for stock points/ timing setup..
