Old 02-09-2018, 12:37 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Replacement Ignition Coil
The replacement ignition coil sold by Model A parts suppliers is a Standard Motor Products UC14T.
http://ecatalog.smpcorp.com/STD/#/ve...m/UC14T?type=s
Does anyone have the output voltage spec for this coil?
Bob Bidonde
Old 02-09-2018, 02:17 PM   #2
3.6rs
3.6rs's Avatar
Default Re: Replacement Ignition Coil
Why would this be important ?
3.6rs is offline   Reply With Quote
Old 02-09-2018, 02:34 PM   #3
Bob-A
Bob-A's Avatar
Smile Re: Replacement Ignition Coil
Go with the Pertronix Flamethrower coil! You will be glad you did......
Bob-A
Bob-A is offline   Reply With Quote
Old 02-09-2018, 02:44 PM   #4
AL in NY
AL in NY's Avatar
I agree with Bob-A, but be sure to order the epoxy filled coil.
Epoxy 1.5 ohm black coil = PN 40111
Epoxy 3.0 ohm black coil = PN 40611
AL in NY
AL in NY is offline   Reply With Quote
Old 02-09-2018, 03:26 PM   #5
Bob Bidonde
6V System
High-voltage output numbers are inconsistent on this forum. I seek the best 6V replacement coil which has the highest output voltage (highest turns ratio).
12V System
40611 Pertronix coils made in China have been recalled because they fail under load. There is another 40611 made in Mexico. There is also a report that some boxes have the wrong part number. What you actually get in the box is a mystery.
I bought a Bosch 00012 and it runs really well.
Bob Bidonde
Old 02-09-2018, 03:46 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
I'm with Bob-A and AL in NY . I use the epoxy filled 3 ohm black coil= PN 40611 on my 12 volt roadster . These coils need no resister . Like Bob-A says you'll be glad you did . I get instant starts and improved power that you can feel . Better spark burns the gas better and gets more power from it. The first thing i did after installation was idel down the carbs.The engine ran so much better , it actually picked up quite a few RPMs .The coil is a 40.000 volt performance part but looks like any normal replacement coil . They even have a chrome version if you would like .
Old 02-09-2018, 04:11 PM   #7
Purdy Swoft
Sorry Bob Bidonde, That hasn't been my experience With the Flame thrower coil .Do you actually have any experience at all with the 40611 coil . It wouldn't matter to me where it was made if it is good . Mine have all been made in Mexico . The 40611 coil that I installed on my roadster has performed flawlessly for the past 12 years . If you can't use it don't try it .
Last edited by Purdy Swoft; 02-09-2018 at 04:19 PM. Reason: added the name Bidonde .
Old 02-09-2018, 11:36 PM   #8
Smog Tech
Smog Tech's Avatar
I use an oil filled 1.5 Ω Pertronix Coil in my 6v Town Sedan. I do mount the coil with the high voltage terminal pointing up.
Smog Tech is offline   Reply With Quote
Old 02-10-2018, 01:23 AM   #9
1930marie
1930marie's Avatar
Does this coil have a stock A look and where can I buy one like you installed? Thanks!
They know enough who know to learn.
1930marie is offline   Reply With Quote
Old 02-10-2018, 09:27 AM   #10
Bob Bidonde
Hi Purdy! Yes, I have a 40611 Flame Thrower, but it failed so I replaced it with a Bosch 00012 (Blue Coil).
Bob Bidonde
Old 02-10-2018, 10:35 AM   #11
katy
katy's Avatar
Contact Standard Motor Products they should have it.
Old 02-10-2018, 10:50 AM   #12
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
You guys need to read this post on the V8 forum........
www.fordbarn.com/forum/showthread.php?t=238737
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 02-10-2018, 11:46 AM   #13
jhowes
A lot of "thanks for the heads up" on the v8 forum but not much in the voltage (6v) or the output. Is it 40,000 or what? I would like to know if they are reliable, is the voltage for our 6v cars, and is the output 40,000 or so? Where do you buy them? I am guessing that the 1.5 ohm is for our 6v systems.
jhowes is offline   Reply With Quote
Old 02-10-2018, 11:53 AM   #14
duke36
Bob: we use Bosch like yours though turned terminals up as in post 8 for oil filled. We have an older tar filled (or whatever medium) 3ohm Bosch (German made) that works well also. The newer ones are supposedly made in Brazil. The oil filled coil we tried gets hot to the touch.
Old 02-10-2018, 12:56 PM   #15
Purdy Swoft
Some have claimed that the epoxy filled flame thrower coils get too hot to touch . I have had no such problem with mine . I could use either the epoxy or oil filled version as long as they are mounted correctly. A high voltage performance coil will no doubt get warmer than a low voltage coil but not that hot . The epoxy version was recommended so I use it . No problems in 12 years .I can grab and hold mine with no discomfort . If others are having problems with the flamethrewer coil , there is no telling what their problem may be . A lot of people use them with results the same as mine .
Old 02-10-2018, 04:18 PM   #16
duke36
Our 12 volt new oil filled gets quite hot but not so much that one can't grasp it. It is cooler than the distributor housing on a warmed engine for reference. The STD UCT coils are made in China. We have also a new UCT15 with internal resistor that measures 4.4 ohms across the primary and 8100 at the secondary.
Old 02-10-2018, 05:14 PM   #17
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Smog Tech,
Where'd you get the OHM symbol in your post?----Or is it a COIL BRACKET?
The Dog & I can't find one on our CHEAP Keyboard
Bill W. & Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 02-10-2018, 06:56 PM   #18
Smog Tech
Smog Tech's Avatar
Bill,
On a MAC the Ω is option z.
Old 02-11-2018, 12:12 AM   #19
40 Deluxe
Answer: It depends!......Depends on how much voltage is needed to jump the plug gap. If only 5,000 volts will fire the plug, that is all the coil will put out. Even if you have a double super whammy "40,000 volt" coil it will still only build up secondary voltage to the point where the spark is strong enough to jump the plug gap, which will never reach 40,000 volts on a Model A, or any stock engine (unless you have totally burned out plug electrodes or open wires, etc.). An ultra high compression or supercharged engine running at wide open throttle may need this much voltage capability, though.
To test coil output, try a "Lisle #20700 Spark Tester". Or, go to a shop with a scope, hook it up and pull a plug wire off and watch the screen.
Old 02-11-2018, 06:41 AM   #20
Tom Wesenberg
Tom Wesenberg's Avatar
I'm not sure if my original coil is reliable, as I'm still testing it. It's only been in use for 90 years.
