01-16-2012, 09:11 PM | #1 |
looking for a decent accurate VOLTAGE TESTER...
What types of voltage testers are you guys using ??? What is the simplest one to give you the answer you're looking for ??
I have a couple that are way too complicated, setting OHM readings and AMPS and all these other dials and knobs that have to be calibrated everytime I use them...........I just want a simple voltage tester for the 6 volt Model "A" electrical system. |
01-16-2012, 09:20 PM | #2 |
Re: looking for a decent accurate VOLTAGE TESTER...
I have several digital meters but I still use my 35 year old Pierce/Simpson 260P.
Oklahoma City Model A Restorers Group. |
01-16-2012, 09:34 PM | #3 |
I use a Fluke 322, very good meter, and easy to use. Also will take a lot of abuse.
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
01-16-2012, 09:36 PM | #4 |
I find an cheap analog type works better as the digitals are subject to the ignition interference. They are harder to read however.
01-16-2012, 09:40 PM | #5 |
Try a FLUKE brand. They even come with a great carrying case that attachs to your belt if desired.They have a wide range of models, but they are great, even for a novice like me...
They are on the higher side of the scale but they aren't just good for auto work, they work on all your electrical needs and are fairly easy to learn to use. Mine is a model 902. GOOD LUCK... Last edited by bobpo; 01-16-2012 at 09:55 PM. |
01-16-2012, 09:44 PM | #6 |
01-16-2012, 09:45 PM | #7 |
Fluke is what I use
01-16-2012, 09:55 PM | #8 |
Odds are the one you get cheap a Harbor Freight will do the job.
I like the Fluke hand held units, they take abuse and keep on working. If you have some idea of what you are doing a nice old Simpson is a great meter. (yes I have one of those too). The analogs do not like to be hooked up backwards and can be hurt with a reverse connection. Having a meter that beeps with continuity is VERY helpful when checking where wires go. The modern digital ones are general pretty good for what you will need. If you are not very familiar with electronics then you just need one that will get you in the ballpark, plus or minus a few tenths of a volt. Cheap ones may break over time. One of my two Harbor Freight units stopped working between uses. It worked when I put it in the drawer and did not work the next time I used it. |
01-17-2012, 12:03 AM | #9 |
It sounds like you have an analog meter that requires you to find the correct scale to read. If that doesn't work for you then you need a digital unit. You probably would do fine with a very inexpensive import but I can't say for sure.
I use both an old analog VOM and an older Fluke 111 multi-meter (which is pretty basic) depending on my needs. However even my basic Fluke probably cost 8-10 times (years ago) the price of a current Harbor Freight import multi-meter so the Fluke meters certainly aren't geared towards the casual user.
http://www.abarnyard.com/ |
01-17-2012, 02:40 AM | #10 |
Here is one of my favorites for a quality inexpensive meter. It also has a buzzer for checking continuity, and battery checks for dry cells and 9 volt batteries.
http://www.ebay.com/itm/W-Sperry-Mul...item2eb552c198 If you want a basic antique volt meter here's one. http://www.ebay.com/itm/VINTAGE-WEST...item2a1852a461 Last edited by Tom Wesenberg; 01-17-2012 at 02:58 AM. |
01-17-2012, 04:17 AM | #11 |
I use a cheap analog as most digitals try to follow fast changes
in current and show nothing reasonable. Last edited by Christoph; 01-17-2012 at 06:38 AM. |
01-17-2012, 08:15 AM | #12 |
I use a Simpson 260 7P and a Fluke 179. Neither are cheap but they are very accurate. The Fluke 179 is also very fast and will follow fast voltage changes.
01-17-2012, 08:48 AM | #13 |
I use a Mastech M9704 that has both analog and digital displays - very handy. It's an import, but costs less than $50. Available online from Amazon and others
01-17-2012, 11:40 AM | #14 |
This HF model is the best $4.99 meter you can buy:
http://www.harborfreight.com/7-funct...ter-90899.html It is reasonably sturdy, and unlike some of the really cheap little analog meters, the test leads are fairly heavy and safe, and have molded connectors. Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
01-17-2012, 12:11 PM | #15 | |
I like how your thinking.
01-17-2012, 12:30 PM | #16 |
Guess I'm one of the few here who doesn't even trust what a cheap $50 meter tells me.
01-17-2012, 01:17 PM | #17 |
Depends on what I am working on, the Model A and non-ECU cars I use a lightweight analog VOM like what Tom Wesenburg suggested. If I'm unsure of the voltage I start with the higher ranges. Digital flickers too much for a glance type readings.
GW |
01-17-2012, 02:18 PM | #18 |
Cheapo harbor freight digital for most of my stuff, cheapo radio shack analog if working on the A while it is running.
01-17-2012, 02:45 PM | #19 |
As a 30 year automotive instructor and a prior test equipment trainer i vote for the Harbor Freight. Cen Tech as well.
I own many meters fluke, lab scopes etc but for the common guy the Cen Tech works just fine. |
01-17-2012, 11:20 PM | #20 |
I like my very old Weidenhoff analog AVR that I picked up for $20 at a swap meet.
01-17-2012, 11:34 PM | #21 |
If you're going to use it on a vehicle with a magneto, buy an analog multimeter. If you need it for messing around in the shop, radio shack digital. If you're going to become an electronics technician or an electrician spend the money for a Fluke. If it's for DC short your screwdriver across the leads, if it's AC pour water on the floor, stand in the water in your barefeet and touch both leads with your fingers. The author of this post refuses to be responsible for any death or dismemberment of anyone who's goofy enough to follow his advice. Have a good day -Mike
01-18-2012, 06:32 AM | #22 |
I find it surprising that many people on Fordbarn will knowlingly buy a Chinese made piece of test equipment because it is cheap.
Personally, I will always buy something that is made ANYWHERE but China even if it means spending a few dollars more, especially when it gets me a better instrument. Eh, but what do I know I'm just a dumb kid. |
01-18-2012, 08:44 AM | #23 |
I agree with Mr. Tube; why spend $5 for the cheapest meter made when you can spend $15 for a much higher quality meter with more features.
01-18-2012, 09:02 AM | #24 |
Because some of us are on a fixed incomes and we can't always afford a meter that cost 3 to 5 times as much as a chinese meter that works fine. I built my own meter when I was in my electronic tech class out of foreign make components from Digikey (pretty much the same as Fluke does) and after 12 years it still works. I bought another one to throw in the truck toolbox from radio shack 5 years ago and other than having to change out the battery it still works. Most of my shop tools are bought at Sears, my clothes at JC Penney, my trucks are always American Made. My multimeters wherever they need to come from to get the job done.
01-18-2012, 10:44 AM | #25 |
I vote with the people who say a cheap analog meter. I keep one in each car for trouble shooting. Digital meters go nuts near a running A. I have expensive and digital meters that I use when precise measurements are required, which is seldom the case with Model A's.
01-18-2012, 05:40 PM | #26 |
For a start - these AVO Minors were made in the 30s. They are analog. They measure in the 6 volt range. They are British..... Yay! I was able to fit a battery into the back of mine and I think it works (they are fairly bomb proof). Sadly it came with only 1 short test lead and the sockets seem to be smaller than the current industry standard ? 3.5 to 4 mm. I'll have to make something up to plug in but has anyone in the Barn got vintage test leads about 3 mm in diameter? |
01-18-2012, 07:02 PM | #27 |
Use a pigtail..a 6 volt bulb ,,,and a couple of alligator clips..this will give you all you need to check a circuit
01-18-2012, 09:58 PM | #28 | |
01-18-2012, 10:14 PM | #29 |
Tom,
I believe you are talking about silicone insulated test leads. They are super soft and you cannot burn it with a soldering iron. They feel much like silicone sparkplug wires. Last edited by MrTube; 01-18-2012 at 10:20 PM. |
