Old 09-15-2014, 01:24 PM   #1
copperpenny
Default battery disconect switch in brass
Anyone remember a recent thread in which a barner in the thread mentioned an ebay listing for a battery disconnect switch made in the USA and was made of brass and not made of pot metal from Chine Had the round disconnect knob.
copperpenny is offline   Reply With Quote
Old 09-15-2014, 01:57 PM   #2
Mike B
Default Re: battery disconect switch in brass
Lot of them come up on Ebay search:
http://www.ebay.com/sch/6000/i.html?...ssories&_rdc=2
Mike B is offline   Reply With Quote
Old 09-15-2014, 02:12 PM   #3
HCO41
Hope you can dig it up. Seems that someone checked out the "brass" connector and after running a file (?) or something over it he found the same old pot metal. May have been Grainger.
Howard
HCO41 is offline   Reply With Quote
Old 09-15-2014, 02:41 PM   #4
packyusmc
packyusmc's Avatar
I don't know about brass but most all the suppliers have those disconnectors. I don't like that type of disconnect because they sometimes don't make good contact. I like the switch with an on/off knob. You can get them at the same places.
packyusmc is offline   Reply With Quote
Old 09-15-2014, 03:10 PM   #5
copperpenny
Thanks guys...brass plating does not make a really safe solution.
Old 09-15-2014, 07:45 PM   #6
russcc
The best battery shutoff switch are made be Cole Hersee, Boston MA. Virtually every race car has one, and I have one on both A's. The are not pot metal, they are a steel housing, with a switch knob the operates a positive, spring loaded, internal detent contact system. I do not know what the contact material is, but you can assume it is brass or copper. You can get the specs from Cole-Hersee. They used to be made in South Boston, but more likely in Mexico today. Be sure to switch the ground side. No ground, no juice, anywhere.
Old 09-15-2014, 08:01 PM   #7
paul2748
paul2748's Avatar
One guy on ebay advertised his as not the cheap ones (pot metal?) but when I asked him what they were made of (brass or copper) he said they were not copper or brass but the same old pot metal. So much for "not the cheap ones"
Old 09-16-2014, 02:37 AM   #8
tiger.1000
It seems that without exception ALL of the green or black knob varieties that fit on the battery terminal are brass plated pot metal (Mazak). They offer a high resistance when in use. Furthermore they are designed to fit on the negative terminal only.
To overcome this problem I made one from solid brass. It works well. I made the tapered hole for the positive terminal using a Snap-On battery taper terminal restorer.
Pics to follow
tiger.1000 is offline   Reply With Quote
Old 09-16-2014, 02:41 AM   #9
tiger.1000
Battery isolator. Only piece I retained from the cheap pot metal version was the plastic insulator
Old 09-16-2014, 06:46 AM   #10
HCO41
Nice work Tiger!!
Old 09-16-2014, 10:12 AM   #11
copperpenny
I'll buy three...
Old 09-16-2014, 10:28 AM   #12
robert dick
i always use the Cole-Hersey switches that my local marina sells --never had a problem with them.
robert dick is offline   Reply With Quote
Old 09-16-2014, 12:44 PM   #13
tiger.1000
There's no doubt that the Cole Hersey switches are excellent however they do not offer the simplicity of the battery terminal mounted version.
If only someone made them in solid brass.
