Old 02-25-2016, 09:46 PM   #1
Lawson Cox
Lawson Cox's Avatar
Default Floor jack craps out after 40+ years
Well, it finally happened after 40+ years. My Sears 2 1/2 ton jack eased down and can't be pumped up enough to slip under my 35 pickup, and hold it up.
I checked the hydraulic fluid and it looks to be okay, just down about 1/4 to 1/2 inch.
Will purchase and add fluid tomorrow to see if that helps. I was just fixing to stick floor jacks under it when it started down. Fortunately no injury or damage. Just a little damn language. LOL Any comments/suggestions considered.
Old 02-25-2016, 10:55 PM   #2
Scotty's 52 F3
Scotty's 52 F3's Avatar
Default Re: Floor jack craps out after 40+ years
Maybe some crud stuck in the relief?
Scotty's 52 F3 is offline   Reply With Quote
Old 02-25-2016, 11:11 PM   #3
Dave D
40 years? Yeah, they just don't build'em like they used too!
Dave D is offline   Reply With Quote
Old 02-25-2016, 11:51 PM   #4
Scott H in Wheaton
Scott H in Wheaton's Avatar
Try bleeding the air out of it.
If I read correctly, loosen the handle as if you were dropping it down. Then slowly pump the handle a few times all the way up and down.
there is a whole thread on the subject over at GarageJournal.com
http://www.garagejournal.com/forum/s...highlight=jack
Scott H in Wheaton is offline   Reply With Quote
Old 02-25-2016, 11:51 PM   #5
larry/Texas
I had the same problem with my Sears jack of about the same age. I went to a hydraulic place and was able to get the necessary parts to fix it and it is still working. I did take my instruction manual with me which helped. I also think I took some of the parts to be sure I got the right parts.
larry/Texas is offline   Reply With Quote
Old 02-25-2016, 11:51 PM   #6
texas webb
Happened to mine last year,looking to get a rebuild kit.Mines about 40 also and American made.
texas webb is offline   Reply With Quote
Old 02-26-2016, 12:47 AM   #7
1952henry
1952henry's Avatar
Check with "Hiball" on garage journal for rebuild kits.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
