10-02-2021, 09:30 PM | #1 |
Ford Racing Performance Stainless Steel Valves
Has anyone used Ford Racing Performance stainless steel valves, specifically M-6507-J302 (Intake) and M-6505-G302 (Exhaust)? Both have 11/32 stems and OAL 5.075. Intakes are 1.94/Exhaust 1.54. I read that they, like many/most others, are made in Argentina.
Thanks Last edited by 55blacktie; 10-02-2021 at 09:44 PM. Reason: wrong forum |
10-02-2021, 10:03 PM | #2 |
Re: Ford Racing Performance Stainless Steel Valves
To start with they are longer than the much used longer than stock chevy valves and 1.94 intakes sounds too big to make any sense. (that is if you are talking about flatheads)
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 10-02-2021 at 10:22 PM. |
10-02-2021, 10:26 PM | #3 |
I mistakenly posted in wrong forum, as noted. The valves are intended for a Y-block. OAL of OEM Y-block valves are 5.09.
10-02-2021, 10:30 PM | #4 |
To answer your question, not I.
Flathead RACING valves most commonly have 5/16 or 7mm stems and are made from titanium. Street valves can be any thing. If you put 1.8 in the ex. and 1.6 in the intake, you will go much faster. I used stainless valves many years ago and they were from John Deere. They had chrome stems for long wear, plenty of stem length for adjusting spring height and big enough heads that could be machined to any size. The valves you list will make the wheels go around but you will be at the rear of the B main. |
10-02-2021, 10:31 PM | #5 |
Ok. scratch what I said.
10-03-2021, 11:45 AM | #6 |
