Old 01-17-2020, 12:55 PM   #1
Road Journey
Default Replacing Wagner Flasher 535
Replacing Wagner Flasher 535 & unplugged flasher before noting what terminal (X, P & L) was clipped into which wire. My three flasher terminal wires are black, blue & red. Don't know if these three wires followed any specific color coding.
36 6 volt positive ground.
How can I get correct flasher terminal on correct wire? Thanks.
Road Journey is offline   Reply With Quote
Old 01-17-2020, 01:05 PM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: Replacing Wagner Flasher 535
This ought to get you there. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 01-17-2020, 01:52 PM   #3
Road Journey
Thanks! You guys are the best.
Old 01-17-2020, 02:52 PM   #4
JSeery
JSeery's Avatar
X is power (input)
L is load (power out)
P is pilot light
I'm not sure how consistent the wire color coding is between different models, but power in should be easy to determine. That just leaves the load and pilot light. Applying power to the wires should let you see which is lighting up the pilot light and which is going to the system.
