Old 02-22-2015, 09:37 PM   #1
roccaas
roccaas's Avatar
Default Control rods feel like they're locked in cold glue.
Worked fine a week ago. Now both are as stiff as my back on a cold morning.
They move, doesn't feel like binding, no noise, just very stiff.
Thanks
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 02-22-2015, 10:00 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Control rods feel like they're locked in cold glue.
Dusty, maybe moisture accumulated in the column & freezes in the AM?? A droplight, with a big bulb might dry it out overnight, or a hair drier, blowing on the column??
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-22-2015, 10:04 PM   #3
John Duden
John Duden's Avatar
Cold grease or oil on the bushings?
John Duden is offline   Reply With Quote
Old 02-22-2015, 10:25 PM   #4
glenn in camino
glenn in camino's Avatar
sprayem with WD40.
glenn in camino is offline   Reply With Quote
Old 02-22-2015, 10:37 PM   #5
Joe K
Joe K's Avatar
How do the links (at the lower end) feel? And with them disconnected you should be able to isolate the issue to the column - if that is where it is.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-22-2015, 11:25 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
My guess is the upper column bushings.
Old 02-23-2015, 12:36 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
I agree with Mike that the top bushing is often the problem. The originals are pot metal and swell with age. My 1928 rods were also very tight, but I kept spraying Kroil on the top bushing and lower end by the springs, and with constant use they have loosened up.
I've heard that you don't want to use WD-40 on pot metal, so I never have. I sprayed WD-40 on a bunch of harware I had stored in a plastic case, and the case is now messed up from it.
Old 02-23-2015, 01:55 AM   #8
Marco Tahtaras
Marco Tahtaras's Avatar
Originally Posted by glenn in camino View Post
sprayem with WD40.
That is often NOT good! Sometimes the stiffening is due to the potmetal swelling. WD40 is know to CAUSE permanent swelling of Model A potmetal. Keep WD40 FAR AWAY from the upper steering bushing and all key locks, especially the popout.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
