Old 10-07-2022, 05:55 AM   #1
springerpete
springerpete's Avatar
Default shock link
At the top of the link is a threaded plug that screws in and then is secured with a cotter pin. How tight should this plug be screwed down ? Thanks, Bill
springerpete is offline   Reply With Quote
Old 10-07-2022, 07:04 AM   #2
barrelnose
Default Re: shock link
I just screwed mine down until there was no movement in the balls then a bit further to get the splitpin in. Been working fine.
barrelnose is offline   Reply With Quote
Old 10-07-2022, 08:21 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Be sure to put lots of grease in the link tube before you put the plug in.
Bob Bidonde
Old 10-07-2022, 08:44 AM   #4
springerpete
Thank you gentlen. Will do what you suggest.
