Old 07-12-2019, 07:15 AM   #1
Admiral
Admiral's Avatar
Default Three-Blade Fans
I know earlier Ford fans and hubs are serviceable. You can disassemble them relatively easily or pull the little drain plug to fill them with oil, but is there any way to service the later 1950 and up three-blade fans? I’m looking at one on my workbench right now and it looks like it has sealed bearings. Can it be rebuilt? If so, how does it come apart? Thanks in advance!
Admiral is offline   Reply With Quote
Old 07-12-2019, 09:59 AM   #2
tubman
tubman's Avatar
Default Re: Three-Blade Fans
They come apart if you have a press and they used a relatively common water pump bearing (I can find the number if need be). I replaced one on my '51. You have to cut the shaft on the bearing down to the correct length and them press the whole thing back together. I tried to do it with my LARGE bench vise, but ended up taking it to a friend who has a 20 ton press.
Old 07-14-2019, 09:55 PM   #3
Admiral
Admiral's Avatar
Yes, Tubman, if you could share that info I'd really appreciate it. I'd like to make certain the bearings in the fan I'm eventually going to run are as good as possible. Also, do you have any instructions/tips for pressing the assembly in and out?
Old 07-15-2019, 06:06 PM   #4
tubman
tubman's Avatar
This was posted by a guy called "8-Track" on the H.A.M.B. : "I came up with NSK 885586 WATER PUMP BEARING on Ebay for $31.00 it is a universal bearing than needs to have the shaft trimmed to fit."
Old 07-16-2019, 07:25 AM   #5
Admiral
Admiral's Avatar
Perfect! Thanks so much for digging this information up. Looks like you can get one on Amazon.com for a few bucks less than eBay: https://www.amazon.com/885586-Integr...dp/B004OENCQC#.
Old 07-16-2019, 11:24 AM   #6
Ross F-1
Ross F-1's Avatar
More info here: https://www.fordbarn.com/forum/showp...0&postcount=10
PS I would not buy the cheapest bearing, I'd get a genuine NSK from a bearing dealer.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 07-16-2019, 03:52 PM   #7
tubman
tubman's Avatar
Take it from Ross. He's the one who got me on to this.
