04-02-2013, 12:55 PM | #1 |
In line fuel filter
Any one out there using a in line fuel filter that will let gas flow just with gravity feed. If so where did you buy it.
04-02-2013, 12:59 PM | #2 |
Re: In line fuel filter
Look for something motorcycle rated or for small engine rated like a big riding lawnmower that does not use a fuel pump. Most NAPA stores can find you a filter when you tell them it is for an older non fuel injected motorcycle.
04-02-2013, 01:02 PM | #3 |
Yep, I use a plain ole filter [ usually a Fram]. I force fit a 3/8" filter in the line [5/16"] between the tank and firewall.
04-02-2013, 01:18 PM | #4 |
We have one inline between the firewall and carb. It's plastic. Looks bad but does the job. We got it from Autozone.
1929 Model A 1992 Galant VR4 474/1000 2007 Prius 54mpg |
04-02-2013, 01:42 PM | #5 |
The glass "cleanable" filters work, too. I have used them with a couple of As, and combination of carbs.
04-02-2013, 01:57 PM | #6 |
04-02-2013, 02:05 PM | #7 |
No filter, just the sediment bowl and never had an issue with sediment clogging my carb. Am I missing something?
04-02-2013, 02:06 PM | #8 |
04-02-2013, 02:14 PM | #9 |
Macs sells a filter that fits inside the sediment bulb. The part number is A9156 and it costs $ 4.75. I use it instead of the inline filter ! Hope that helps !
Al |
04-02-2013, 02:22 PM | #10 |
this is what i use in addition to the side bowl filter
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
04-02-2013, 02:28 PM | #11 |
Please do read the thread that Barracuda Boy recommended.
My opinion is that the filters work well for people whose systems are so clean that they really don't need them. Also, be aware that vapor lock season is just around the corner, whereupon the filters will provide a whole new opportunity for problems as loci for vapor bubbles to hang up. Steve Last edited by steve s; 04-03-2013 at 08:48 AM. |
04-02-2013, 03:28 PM | #12 | |
just like Henry designed it .
I've suffered a great many Catastrophe's in my life.....most of them never Happened. |
04-02-2013, 05:19 PM | #13 |
The original type filter inside the cast iron sediment bowl does an excellent job for me, I also use the standpipe filter in the top of the fuel valve just to be SAFE from any big chunks. Bill W.
04-02-2013, 08:19 PM | #14 |
I too use a filter in the glass sediment bowl. It looks good and doesn't 'clutter up' the engine compartment. I'm weird, inline filters look like an after thought. Personal opinion only. I did pick up a spiral spring at Ace Hardware to keep it in place. Looks natural.
Mike Stitt "A business that make nothing but money is a poor business." -Henry Ford |
04-02-2013, 08:22 PM | #15 |
Autozone - clear plastic filter bwtween glass bowl and carb.
04-02-2013, 09:23 PM | #16 |
On my coupe I have the stand -up screen in the shutoff valve.I havnt had the glass sed bowl off in 14,000 miles & still cant see any crud in it.
04-03-2013, 12:05 AM | #17 |
This is what I did a while back just for the feel good sake of it. Didn't like the plastic ones so I took my time and built this. It's worked out well for me and it doesn't stick out too bad.
04-03-2013, 12:10 AM | #18 |
I am with Bill W. On this one.
04-03-2013, 05:51 AM | #19 |
2x with Bill W. and Drive Shaft Dave. Why the extra filter if not for piece of mind would you need it? If your carb is blocking up the issue is the gas tank rusting and there is no way of just washing it out or flushing it that will stop it but boiling it out and sealing it.
You can pay now or pay later. |
04-03-2013, 12:01 PM | #20 |
KMeredith87
I am running the same filter, works great . I assume you have a fuel shut off valve in the cab of the truck. |
