Old 05-21-2021, 01:12 PM   #1
rfitzpatrick
Default Boat Anchor
When I'm heavy traffic in my PicUp, and I finally get third-gear? It's like I threw out a boat anchor -- my acceleration is so very slow. It's an all
stock Budd. Got one of then Slow-Vehicle logos on my tail-gate that no one
honors. Once I get going, I'm keeping up with traffic. This is getting dangerous.
Thanks -- I Feel Better
rfitzpatrick is offline   Reply With Quote
Old 05-21-2021, 01:57 PM   #2
HDowse
HDowse's Avatar
Default Re: Boat Anchor
Is the engine timed correctly? Is the spark advanced down about 2/3rds? The parking brake is off and the brakes aren’t dragging? Check all that and don’t compare the A with your Tesla......
HDowse is offline   Reply With Quote
Old 05-21-2021, 02:10 PM   #3
Blue-Truck-Nut
Blue-Truck-Nut's Avatar
Through much research, I can attest that the Model A's performance is severely lacking when operated as a raft, boat, or submarine. I humbly suggest enjoying ones Model A on dry land.
As for traffic, you aren't alone. Drivers are paying less attention than ever to what is in front of them, behind the steering wheel of faster more responsive cars than ever. I've noticed an exponential change within just the last year, defensive driving is more critical now than ever.
Sent from my E6810 using Tapatalk
Blue-Truck-Nut is offline   Reply With Quote
Old 05-21-2021, 05:23 PM   #4
Pdgx
Pdgx's Avatar
I’m sure it’s at least as warm down there as it is here already. I’d suggest you open your air/fuel adjustment a little bit more and see if it helps your setup.
If you’re driving it a lot in traffic, might consider a Mitchell OD, as the 2 to 3 shift is a bit much, and you can bog down if you have any grade.
Pdgx is offline   Reply With Quote
Old 05-21-2021, 05:32 PM   #5
nkaminar
nkaminar's Avatar
Are you looking for answers or just complaining. If you want better acceleration, you know what to do. Regarding people riding your exhaust pipe, I put a camera in my rear window to record any accident. The cops know how to view the video which will let them see the person texting and not paying attention.
Old 05-21-2021, 05:51 PM   #6
rfitzpatrick
[QUOTE=nkaminar;2018840]Are you looking for answers
YES
Old 05-21-2021, 06:49 PM   #7
Blue-Truck-Nut
Sarcasm aside......
Is this problem a recent development? Or has it always been this way?
First, is it a low power issue, or something keeping the car from coasting freely? ( See post #2)
I would start diagnosing by cleaning the fuel screen, and verifying good fuel flow at the carb.
Next, I would use a screwdriver or some such instrument to short the spark plugs, make sure it's hitting on all 4, that's also the time to verify good hot spark, if I get a good solid arc 1/8" or more I'm happy. If not, check the points. ( Don't do this step with fuel everywhere from the first step, for obvious reasons.)
Next, pull the spark plugs and look, is it running too lean? Too rich? Are the plugs varnished? Clean and gap or replace as needed.
That's how I would start, and proceed depending on what I found there.
Good luck!
Old 05-21-2021, 07:32 PM   #8
Ian in Mississauga
What speed are you shifting at? I get the same result as you if I shift under 20mph.
Ian in Mississauga is offline   Reply With Quote
Old 05-22-2021, 08:41 AM   #9
TerryH
TerryH's Avatar
The Model A has a big gap, shifting from 2nd to 3rd…..so I never shift at less than 20 mph. 3rd will pull better than……
TerryH is offline   Reply With Quote
Old 05-22-2021, 08:54 AM   #10
Jack Shaft
This is a boat anchor
Old 05-22-2021, 09:01 AM   #11
Jack Shaft
I built mine to battle with the yoyo's on the road today..hell If I can gap a Kia Rio if i catch it napping..actually a model a putting out about twice the power with a mitchell OD is capable of competing in todays combat conditions..without protection of a convoy,and any time of the day
Old 05-22-2021, 10:10 AM   #12
Mister Moose
Mister Moose's Avatar
Henry built the Model A as a 4 speed, and then to reduce costs he left 3rd gear out. When you think of it as 1st, 2nd and 4th, you'll be in the right frame of mind. If the car pulls strong in 1st and 2nd, you likely have normal performance. There's a reason so many folks put in overdrive, as it not only gives you a higher gear for highway, but a higher 2nd gear for hills and acceleration.
Mister Moose is offline   Reply With Quote
Old 05-23-2021, 10:55 AM   #13
Big hammer
Check and see if your throttle is opening wide open
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 05-23-2021, 11:41 AM   #14
rfitzpatrick
Thanks everyone.
I've gone over the ideas mentioned. Now once I get up to speed, it'll do 50 real easy
but that doesn't feel safe. It'll take a few miles of open road to reach that. It has a 3.78 rear-end --
Thanks
Old 05-23-2021, 12:56 PM   #15
Charlie Stephens
Thanks everyone.
Thanks
Find a local club and see if you can locate someone to look at your car. Maybe bring it to a club meeting. It is not performing right and sounds dangerous to drive.
Charlie Stephens
Old 05-23-2021, 01:45 PM   #16
nkaminar
nkaminar's Avatar
Aside from the usual things to make a car accelerator faster, there are some less obvious things to check. Check to see if there is an obstruction in the tail pipe or muffler or if it is a very restrictive muffler. You can just disconnect it from the exhaust manifold and tie it up with some wire or rope to see if that makes a difference. (Car will be louder.) (An old high school trick is to shove a potato up an exhaust pipe as a joke.) Check the intake manifold and exhaust manifold for restrictions. Do the gaskets have undersize holes? Do the coast test as others have suggested to see if there is some parasitic drag.
There is always the option to send the engine to someone to rework it. $$$
Old 05-23-2021, 07:53 PM   #17
jayvee34
jayvee34's Avatar
saw this bumper sticker on a car driving the speed limit.
"SORRY FOR DRIVING SO CLOSE IN FRONT OF YOU"
IN GOD WE TRUST - SEMPER FIDELIS
John
jayvee34 is offline   Reply With Quote
Old 05-23-2021, 08:29 PM   #18
shew01
shew01's Avatar
Lol
Old 05-23-2021, 10:21 PM   #19
Blue-Truck-Nut
Hahaha! That's great.
My favorite Red Green quote is "The fastest way to irritate a stranger is to drive the speed limit."
Old 05-24-2021, 06:58 AM   #20
nkaminar
nkaminar's Avatar
The speed limit on the freeways around Washington DC is 55 mph. Try driving that slow and you will get run off the road. Traffic flows at 70 mph or more. I don't understand.
