02-04-2020, 09:57 PM | #21 |
Re: New member, new project
Got it, cool story.
Rob |
02-05-2020, 06:40 AM | #22 | |
Gary MacDonald |
02-05-2020, 07:42 AM | #23 |
Welcome to the barn, nice looking project, post some more pictures when you get her cleaned up.
02-05-2020, 08:19 AM | #24 |
Welcome Fasttoys. Love 35s, specially slant backs. Git er cleaned up & run'n and drive it, like others have said. Only original once. And, i like the white walls.
Have fun !!! |
02-05-2020, 08:24 AM | #25 |
Man, that’s a great “first old ford”.
02-05-2020, 11:53 AM | #26 |
Nomad |
02-05-2020, 12:10 PM | #27 |
Not to hijack this thread, but I have to say, "Anthony, your car looks great!".
02-05-2020, 12:17 PM | #28 |
Cool looking car Anthony, So this thing is turning into a treasure trove. It had a box with what I thought was the generator behind the drivers seat, after pulling it out I realize it is a alternator conversion of some sort. Now behind the rear seat, that's where the fun begins. Take a look at the pictures I know what most of it is, but not sure about the red handled tool. Kinda looks like a seal puller? Also looks like most of the factory tools are present. Missing what? It also came with an extra set of front seats.
Rob |
02-05-2020, 12:58 PM | #29 |
Looks like some useful parts there. You ought to be able to have it running and driving pretty quick.
Nice looking car. Those are the best project cars to buy, pretty complete and with useful spares thrown in. Win win. Mart. |
02-05-2020, 12:58 PM | #30 |
Thx Tubman, U, JSeery, DD & a bunch more of u guys were a Giant help
With everyone’s help you’ll get there too Fasttoys
Nomad |
02-05-2020, 01:25 PM | #31 |
looks like you are missing the crank ext. bar-has a cross on one end and a square tapered on the other-goes into the tapered square in the end of the lug wrench
02-05-2020, 02:03 PM | #32 |
hi Rob, welcome to the barn,,,nice project you picked up there too.
Also, the red handled thingy is a left & right ratcheting multi-tipped screwdriver. You might have to get some penetrant fluid in the area where the tips are. You pull the multi-tips out, and then turn the tip you want to use, outward. .
If mama ain't happy, ain't nobody happy. But if daddy ain't happy...RUN |
02-05-2020, 02:32 PM | #33 |
Lanny's right. I remember my dad having one of those. There should be a little lever right below the red handle that you move to activate the ratcheting mechanism. As I remember, there was a phillips tip and two different sized conventional tips.
02-05-2020, 03:23 PM | #34 |
Hi Everyone. Nice snag Fasttoys! I inherited a '36 Phaeton and bought a '35 Fordor Touring a few years ago.
I've found Third Generation Automotive a great resource for original or correct repro parts for my projects. There's a thread floating around on recommended vendors somewhere. I'd ask him about the bits to fix up your headlights. If those are '35 water pumps you might want to send them to Skip Haney in FL for a rebuild. He can do the dizzy too. And fix you up a couple new coils and tested condensers you send him. Your tool kit is missing a straight blade screwdriver and a spark plug wrench and a grease gun and an adjustable wrench. Keep posting on this thread and it will become like a history timeline. If you don't have one yet, you'll love the V-8 Club's 1935-36 book. It's about $30 and available on the V-8 Foundation page and the V-8 club site.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? Last edited by VeryTangled; 02-05-2020 at 03:33 PM. Reason: remembered to recommend the book |
02-05-2020, 05:02 PM | #35 |
Thanks everyone, Ill check out Book and website, what am I missing on the headlights? In the spare parts there are 2 Bob Drake buckets with replaceable bulbs, maybe Ii need glass lenses?
Rob |
02-06-2020, 12:53 PM | #36 |
Thx Rob, you ‘35 Tudor looks like a great start. Mine looked similar and was amazed after a good cleaning & waxing how good it looked. I as I think you will w Barner’s help enjoy the build! BOL.
Nomad |
02-15-2020, 04:26 PM | #37 |
So I starting a bit of a check-out and some testing, Ran a compression check only to find it was very low, as in 0 on 3 cylinders and max of 50 PSI. A couple or shots of oil helped and a bit of penetrating oil and now I have some compression across the board. I figure if I can get it to hit a few licks it can only get better. With that as a goal I started looking at the fuel system, as you can see, the gas was the color of root beer and smelled dead. I tried to pull the drain plug on the tank to no avail. Set up a 12 volt pump and used a jump-it box to pump about 2 gallons of root beer, put 1 gallon of fresh gas and repeated this 3 times. I think it should be good enough to fire it off, time will tell. Final picture is new fuel compared to whats coming out of tank now.
More later. Rob |
02-15-2020, 07:28 PM | #38 |
Good luck ,it should at least pop and start . I do like that car !
02-15-2020, 08:44 PM | #39 | |
02-15-2020, 09:17 PM | #40 |
Looks like a headlight conversion to my eye. Original ones have a goofy shaped bulb with a PITA mount using three spring loaded attachments!
