Old 01-31-2020, 05:13 PM   #21
rotorwrench
rotorwrench's Avatar
Default Re: 8cm cam grind
The 1CM cam came about for the change over to the rotator type valves and the automatic transmission.
Old 01-31-2020, 06:47 PM   #22
tubman
tubman's Avatar
That makes a lot of sense. The automatic transmission would seem to me to require a milder cam for a smoother idle to accommodate idling in gear when stopped. Maybe, maybe not.
Old 01-31-2020, 07:03 PM   #23
Mart
Mart's Avatar
May I ask if there is a (best) stock cam for the pre 8ba style motors with the front mount dizzy?
Old 01-31-2020, 08:41 PM   #24
cas3
get the merc cam and cut the gear off mart, piece o cake for you
Old 01-31-2020, 09:15 PM   #25
flatjack9
flatjack9's Avatar
Have the Merc cam ground on an early core.
Old 01-31-2020, 09:35 PM   #26
flatjack9
flatjack9's Avatar
Originally Posted by tubman View Post
Just out of curiosity, does anyone know if there are "1CM" ('51 Mercury) or "EAC" ('52-'53 Mercury) separate grinds?
I dug through my cam charts and found that I did degree a couple 1CM cams and for all practical purposed they are identical to the 8CM.
Old 01-31-2020, 09:48 PM   #27
Brian
Brian's Avatar
In my opinion, yes; the 32-34 steel cam. In 1935 with the introduction of the bigger, heavier bodies, along with cast iron camshafts, Ford 'detuned' the cam timing.
Old 01-31-2020, 10:44 PM   #28
flatjack9
flatjack9's Avatar
Do you have some specs to compare the cams?
Old 01-31-2020, 11:24 PM   #29
Brian
Brian's Avatar
Only some;
year engine valve lift inches intake opensBTC intake closesABC exhaust opens BBC exhaust closesATC
32-34 V8 85 .292" 9.5 * 54.5* 57.5* 6.5*
35-42 V8 85 .292" 0.0* 44.0* 48.0* 6.0*
46-49 V8 100 .292 0.0* 44.0* 48.0* 6.0*
[1949 intake increased to .296" lift]
Old 02-01-2020, 12:14 AM   #30
cas3
so my 34 motor that they left water in to freeze in not a boat anchor after all!
Old 02-01-2020, 12:32 AM   #31
cadillac512
cadillac512's Avatar
8CM that I degreed when building the 260 Merc:
9* 53* 50* 7* (checked at .014/.015 lash)
.330 lift at 0 lash
Compares nicely to the 32-34 cam Brian posted above. I think it'd be nice with the front modified for the early engine. An EAB cam is also very close to these numbers when advanced 4 degrees.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 02-01-2020, 06:07 PM   #32
flatjack9
flatjack9's Avatar
Originally Posted by Brian View Post
Only some;
Any ideas what lift these numbers were taken at?
Old 02-01-2020, 06:11 PM   #33
Tim Ayers
I thought somewhere I saw the EAC is .320" lift. I'm surprise the stock ones are less than .300". Seems like such little lift.
Tim Ayers is online now   Reply With Quote
Old 02-01-2020, 06:28 PM   #34
Frank Miller
Frank Miller's Avatar
Tim,
Those numbers do not jive with these.
https://www.tildentechnologies.com/C...rformance.html
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 02-01-2020, 10:51 PM   #35
flatjack9
flatjack9's Avatar
According to Tilden, Ford took spec'd their cams at .015 lift.
Old 02-01-2020, 10:58 PM   #36
Ol' Ron
Ol' Ron's Avatar
You can install an 8ba style cam in an early block and front cover. Then you can run a late style distributor. W do this all the time
Old 02-01-2020, 11:03 PM   #37
flatjack9
flatjack9's Avatar
I've never seen an EAC cam. I have cams marked EA and EAB. EAB had .307 lift and the EA had .330.
Old 02-03-2020, 07:21 AM   #38
Tim Ayers
I’ll look again at the cam. The lift numbers were going off memeory so they may not be correct.
