Old 01-14-2020, 02:46 PM   #1
RRW
Send a message via Yahoo to RRW
Default New gasket for 1930 radiator cap question....
I removed the original gasket from my repro cap and my new gasket 'floats' in the cap between the copper 'gasket' and twist clamp.
Original gasket was larger and was a snug fit as it was installed during production.
New gasket has a larger center hole so it will fit over twist clamp and is loose.
Should I adhere the new gasket with a sealer or leave as is?
Thank you from Bullhead City
RRW is offline   Reply With Quote
Old 01-14-2020, 03:38 PM   #2
Gary WA
Gary WA's Avatar
Default Re: New gasket for 1930 radiator cap question....
Id say no sealer!
www.whidbeymodelaclub.com
Old 01-14-2020, 05:03 PM   #3
J Franklin
J Franklin's Avatar
As long as it won't fall off don't worry about it.
Old 01-14-2020, 06:32 PM   #4
RRW
Thank you both for your replies.
No sealant 'it is'.
Old 01-15-2020, 06:46 PM   #5
CHuDWah
CHuDWah's Avatar
I had a repro quail on which the fiber gasket was too thin so the cap rattled. I got a rubber O-ring of the right diameter at the hardware store - no more problem.
CHuDWah is offline   Reply With Quote
