12-04-2019, 03:17 PM | #1 |
Replacing rings on 1 piston on 8ba
Anyone know if I can get the rings and rod bearing for one piston any where? C&R & Speedway only sells as sets for all 8.
Nomad |
12-04-2019, 03:27 PM | #2 |
Re: Replacing rings on 1 piston on 8ba
I'd first ask Mac VP.
Enjoy yer day. Tom Hate can't fix what it started. |
12-04-2019, 04:14 PM | #3 |
Phone Hastings they will sell you a single set of rings for 1 cylinder
R |
12-04-2019, 05:32 PM | #4 |
Stock Pistons ? What size bore ? I may have a few
12-04-2019, 06:10 PM | #5 |
Same here, let me know what size.
Sent from my SM-G960U using Tapatalk |
12-04-2019, 07:26 PM | #6 |
Thx A bones & Ronnie, I'll check with both Hastings and VP JIC.
Nomad |
12-04-2019, 10:43 PM | #7 | |
41 woodie https://41fordwoodie.weebly.com/ |
12-05-2019, 05:16 AM | #8 |
Hey Anthony - just to ask a question: When was this engine built and what do you think happened to it? Rings are not that expensive - and you're already pulling the engine and putting a lot of time into it.
If it was mine, I'd probably plan to pull all the pistons, check the bores and maybe hone and re-ring the whole thing? It kind of depends on what you find when you pull the one cylinder (like a broken ring) . . . but do keep in mind whether or not to do all 8 of them. Also, I'd measure the bores accurately to see if they are worn, tapered or too "loose" for the pistons. Sometimes folks throw these engines back together with the "least amount possible" of work . . . so check it all out. |
12-05-2019, 07:22 AM | #9 |
Times 2 on what Bored&Stroked said. Honed & re ringed an 8BA & a smc some years ago.
It isn't perfect, but greatly reduced oil use & improved performance. |
12-05-2019, 08:26 AM | #10 |
I re ringed and put new bearings in a 72 K10 that was blowing oil. It needed more but that was all I had. Drove it for about 5 years after that and sold it to a guy who did a little work and said it ran mint. He drove it for a few years too. I plowed with it too.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
12-05-2019, 11:19 AM | #11 |
Here’s the story on the engine, purchased from United Specialists Engines in Wichita Ka. In 2013 w 12,000 2yr warranty. I have approx 2000 miles on it, I know a lot of u guys drive’em a lot more but gotta believe I’m in the average for a cruise nite toy. Anyway had problems when first bought & under warranty which should’ve been a clue. Had wrong pressure plate on FW that busted case on my ‘35 Tranny ( had to rebuild w good case), Fly Wheel drilled for pressure plate .090 out of concentric, E-distributor bad. United Speciaists sent new parts 4 all but damage & labor for their mistakes was on my time & $. Fast forward to now, before putting away for season I usually take out for long ride bring revs up to blow carbon out from slow driving all season. Did this yr in early Oct as was leaving for long Vacation in Nov. When I got home noticed smoke from engine, it was puffing ( in Rhythmic puffs see other post) coming from oil fill neck. No smoke from tail pipes! Checked compression good all cyl’s except #2. Pulled that head to see if any cyl damage could see none but could tell water had gotten into cyl 4 at some point (cyl had water stains but bore smooth & compression ok. Changed head gasket rechecked compression w same results as before. Tried to drive a few times based on suggestions from previous post. Rhythmic puffing from oil Fill neck got worse & heard odd lower end noise but still no smoke from tail pipes. Arrived @ Current decision to check lower end (think it's a cracked oil wipe ring or possible compression ring letting compression get to crankcase on cyl #2) so change rings on bad compression cyl 2, but will give all a good look. Rational is, engine has so few miles on it and only has the compression issue on the #2 cyl so seems that's probly the issue.
Nomad Last edited by AnthonyG; 12-05-2019 at 11:36 AM. |
12-05-2019, 01:00 PM | #12 | |
Did the oil pressure drop, at all, after the puffing started? The other thing that I'd check out is the wrist pin and piston. Can you describe the odd noise?
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
12-05-2019, 06:07 PM | #13 |
Initially thought it was spark plug knock as engine runs rough when it occurred. Increase revs a bit it diminishes. Comes & goes. When audible engine puffing smoke increased. Didn’t want to keep going was afraid of cyl damage. So far no smoke from tail pipes so think cylinders still OK, I hope. Will not run again till I see in side the bottom end. All has to b related. Pretty hard to diagnose w specificity
Nomad |
12-05-2019, 06:14 PM | #14 |
I thought Oil pressure was always weird but been told it’s normal for a Flatty. Runs from 15psi up to 45psi w higher rpm’s
Nomad |
12-06-2019, 01:41 AM | #15 |
A broken piston, might make more since than a broken ring.
We will all be interested in what you find.
12-06-2019, 01:29 PM | #16 |
Hoping it’s obvious!!! I’d hate to see again after this effort
Nomad |
12-13-2019, 07:19 PM | #17 |
Fast check of bore w dial calipers is 3.310”-3.314” for tings
Nomad |
12-14-2019, 04:41 AM | #18 |
From those numbers +.125" over is my best guess. Didn't realise it was already well oversize.
12-14-2019, 08:03 AM | #19 |
I don't have any that spare rings that large . Sorry
12-20-2019, 04:43 PM | #20 |
Frank nailed it in post #15, broken piston, no broken rings. Makes more sense as Frank said. Once piston removed could see crack between top 2 ring grooves. Piston skirts & top of one side dragging on cyl, w piston out can see aluminum marks in cyl. Feels fine to touch. Can’t feel any cyl damage, aluminum against iron the iron won. 100% sure cyl is good & light hone will remove marks. See pics of piston, couldn’t get a shot of inside cyl that showed anything.
Nomad |
