Old 07-17-2019, 07:15 AM   #21
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Re: options for electronic ignition conversion on my '41
Originally Posted by drolston View Post
I think I meant what you thought I meant. In summary, the Bosch blue coil has 1.5 ohms of additional resistance over the resistance of the windings, so an external resistor is not needed.
The primary winding of the Bosch Blue coil is wound so it has approx 3.0 ohms of resistance from end to end,there is no resistor etc in the coil.
Coil winding wire sizes changes with needs and output requirements. Center steel laminets wire size ( as well as position some put primary windings in the center and other makers put it on the outside) . Each coil has a inductor rating for the job. The low compression of the flatheads make this a easy job for most coils....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 07-17-2019, 07:32 AM   #22
RKS.PA
RKS.PA's Avatar
Guys, it seems like the preference for electronic vs. stock ignition is highly personal, with undying fans on each side......a little like the 6 volts vs. 12 volts conversion pros and cons.
I have both electronic and "conventional" or stock ignitions on my cars. When the electronic (Pertronix) failed, my solution was AAA with the roll back to get back to my house where I could fix it. Carrying a spare distributor etc. and changing it roadside isn't my idea of a good time, but I could do it and admire those who do.
I love the electronic ignition that the PO put on the car that has it.....12 volts and instant starts etc. I also love the 6 volt conventional...Bubba crab and Skip coil... that's on the the car set up that way.
So, to each his own...and I am thankful we have the options and the tech support to keep each one going!!
RKS.PA is offline   Reply With Quote
Old 07-17-2019, 08:38 AM   #23
randy993
randy993's Avatar
I want to thank everyone for the replies and suggestions. I beleive for now I'm going to stay with the stock set up. I've ordered a service manual and hope I can get educated on how to service it.
Thanks again,
randy993 is offline   Reply With Quote
Old 07-17-2019, 09:32 AM   #24
tubman
tubman's Avatar
Thanks again,
A good plan that's not dependent on the type of ignition you choose.
Old 07-17-2019, 09:46 AM   #25
RKS.PA
RKS.PA's Avatar
Thanks again,
Despite my natural resistance and lack of talent, the "learning and getting educated" is my number one source of happiness with this hobby!
Tubman nailed it in his post above!!!
Old 07-17-2019, 10:00 AM   #26
4dFord/SC
4dFord/SC's Avatar
Or which oil to use in a flathead.
4dFord/SC is offline   Reply With Quote
Old 07-17-2019, 07:34 PM   #27
Tinker
Tinker's Avatar
Originally Posted by marko39 View Post
fa54
Thanks Marko. I might order a few from napa and mess around changing them out to see if I feel a difference.
I might also buy tubmans version too. Seems like a very good one. Pre-tested anyways.
Old 07-18-2019, 10:22 AM   #28
ct1932ford
ct1932ford's Avatar
Originally Posted by solidaxle View Post
How much of a difference is there when you use another coil?
The resistance needs to be correct for the module requirements. I think 1.5
All the failures I have seen were using the wrong coil.
A man should do what he thinks best! "The Duke"
ct1932ford is offline   Reply With Quote
Old 07-21-2019, 12:14 PM   #29
BUBBAS IGNITION
Yep every time.......
[email protected]
