12-05-2013, 03:21 PM | #41 |
Re: 59A oil leak
I only put 130,000 on my 39 convertible plus over 100,000 on my other old Fords in the past 32 years. I have driven many 1,200 mile trips in 2 days in the 39 and several others. You don't see me with all these problems. In fact I have had very few minor problems on any of my old Fords.other than with this new gas. I live where it's 90 or more most of the year and this fuel problem shows up more in heat. Do it right the first time and these engines will run trouble free for years we have better oil today than in the 30's, 40's and 50's. No sludge. G.M.
www.fordcollector.com |
12-05-2013, 03:37 PM | #42 |
Re: 59A oil leak
Same old George. Merry Christmas, George.
Alan |
12-05-2013, 03:46 PM | #43 | |
Re: 59A oil leak
Looks like you went a little heavy on the Rogaine. No wisdom. No pride. No boasting. Just dumb luck, I guess (again).
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 12-05-2013 at 03:57 PM. |
12-05-2013, 04:05 PM | #44 | |
Re: 59A oil leak
I scratch my head at any one who, as a result of of some itsy bitsy oil leak, would give up a glorious road trip. (I carry AAA Plus that will tow 300 miles, just in case. Never have had to use it on a road trip (KOW). The slim possibility of such does not deter me from the joy of the trip but I always consider such risk and accept it and am prepared for such, just in case.)
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 12-05-2013 at 04:24 PM. |
12-05-2013, 04:54 PM | #45 |
Re: 59A oil leak
I certainly NEVER said anything about giving-up a glorious road trip. I just don't understand the wisdom of "band-aiding"/mickey-mousing such an important system as your OIL supply...the life-blood of your engine, and then "hoping" it doesn't come un-glued before returning to civilization. Fix it RIGHT to begin with, then carry-on, knowing that particular malady is no longer an issue. What if the airlines "fixed" airplanes your way just to stay on schedule? DD
12-05-2013, 05:58 PM | #46 |
Re: 59A oil leak
but only a small amount of oil was coming out. Oil filter lines also had to be wound back in a little, cinched down. good luck. |
12-05-2013, 06:46 PM | #47 | |
Re: 59A oil leak
I apologize, as I should have in advance of my report, (and have since added to my report) for upsetting you with my "band-aid" approach. I appreciate your instructions on doing the job right and will certainly pursue that approach if I ever have to remove the pan for anything else in the future but as long as my "band-aid" is working I'll stick with that. I have not and would not advocate my "band-aid" as the correct, right, nor best repair - only that it worked for me under these urgent circumstances and might come in handy for anyone else so situated. I hope that you will continue to offer suggested solutions to my problems even though I may not do them all the time. We all have varying degrees of tolerance to imperfection. As I've said before, I'd much rather drive an imperfect car than have a perfect one just sitting in the garage. You have good ideas and I appreciate you sharing them.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 12-05-2013 at 06:55 PM. |
12-05-2013, 09:44 PM | #48 |
Re: 59A oil leak
Old Henry,
Thank you for all your informative posts. Some people, if they can't dazzle us with brilliance, will try to baffle us with BS. |
12-05-2013, 10:17 PM | #49 |
Re: 59A oil leak
I'd say, In my humble opinion, this is/was a good fix, if you are a long way from home...heck, even 50 miles away.
But me personally knowing I had a road trip coming up in a month, would probably find an hour here and there to take it apart and make a known permanent solution. I guess we all have our ways, via our means, but I have to side with GM here, do it right once is usually the best approach. |
12-05-2013, 10:47 PM | #50 |
Re: 59A oil leak
No question about it. I totally agree. . . usually, as you said.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 12-05-2013 at 11:04 PM. |
