Old 08-03-2023, 09:46 AM   #21
Kube
Kube's Avatar
Default Re: Tips/tricks for getting seriously stuck pistons out of the block
Tim, I hope for your sake, you will be more fortunate than I was the last time I'd attempted to save a block that appeared much like yours. After all the effort, a boiling and finally a pressure test, well, that block is now a boat anchor.
Old 08-03-2023, 02:22 PM   #22
Newc
Newc's Avatar
My problem is aluminum finned heads, some of the head studs have come out, but still stuck. Sharp's heads too !! Newc
Old 08-03-2023, 02:30 PM   #23
tubman
tubman's Avatar
Use an 11/16" deep hole saw on the offending studs and then use properly sized aluminum tube to bush the holes. This actually improves the stability of freshly installed heads as the holes are usually pretty sloppy from the factory.
Old 08-03-2023, 05:09 PM   #24
Tim Ayers
Kube,
I'm kind of thinking this block will end up like your experiences. I'm going to give it a go since I'm so deep into it.
Tim
