11-06-2019, 12:02 PM | #1 |
Update on transmission plug
I haven’t updated my original post because my car is 100 miles from my house. I cleaned the plug and with a little muscle and a very large adjustable I got it off. The case isn’t cracked but the oil came out very dirty compared to the rear which looked clean. My question is I was thinking of filling it with transmission fluid and take it for a ride then drain it as soon as I got back. Good or bad idea.
11-06-2019, 12:16 PM | #2 |
Re: Update on transmission plug
Transmission fluid?
600w transmission oil needed. I use half STP and half 600w oil from suppliers. I would leave plug out and let drain for a couple of days before refilling with new oil. |
11-06-2019, 12:40 PM | #3 |
If you want to flush it out with thin oil rather than gear lub, I think it would be better to jack up a rear wheel and don't add the load of driving it on the road. Or you can remove a few bolts and do a thorough clean from the top. This will give you an opportunity to do a visual inspection.
11-06-2019, 01:13 PM | #4 |
With plug out, take air hose with plastic/vinyl hose insert in oil fill area and try to blow out more oil,better to pull pan and clean , also valve cover area cleaning.
www.whidbeymodelaclub.com |
11-06-2019, 01:19 PM | #5 |
FWIW, Ford recommended flushing with Kerosene.
11-06-2019, 02:14 PM | #6 |
11-06-2019, 02:24 PM | #7 |
Just use the kerosene and then fill with new 600 oil. Put a new plug in that fits and seals.
11-06-2019, 02:34 PM | #8 |
Pull pan? On the transmission?? Valve cover??
The Master Cylinder Enjoying life at the beach in SoCal... |
11-06-2019, 02:43 PM | #9 |
As Jack says. Just fill with Kerosene and drain, maybe rock the car to slosh it if you want. I wouldn't drive it any distance without 600W in it. Also, when you say dirty what exactly do you mean? The 600W that Brattons sells is dark brown right out of the container.
11-06-2019, 03:17 PM | #10 |
Post #3 is a safe thorough way to use kerosene. you only need to run it a short while and by running it, it will flush out the bearings in the cluster as well as splashing it all around the case and tower parts.
11-06-2019, 03:23 PM | #11 |
Never knew Ford recommended Kerosene. I've used Diesel in the past.
Sent from my E6810 using Tapatalk |
11-06-2019, 07:07 PM | #12 |
11-06-2019, 07:14 PM | #13 |
11-06-2019, 07:41 PM | #14 |
use care flushing with thin fluids. when I did it with motor oil, the oil migrated out the input shaft and made a mess on the pressure plate andclutch.
11-06-2019, 08:02 PM | #15 |
Thanks for the suggestions. I think I’ll fill it with kerosene, shift through the gears and drain it.
11-06-2019, 10:30 PM | #16 | |
Years ago, we visited my wife’s friend in Mexico City. I went with her husband when he was getting an oil and transmission fluid change. That’s what they did. Filled both with kerosene and rocked the car back and forth then drained the kerosene and filled it with oil and transmission fluid. I think it would be ok to do that with the transmission but I’m not sure I would do that with the engine oil. David Serrano |
11-06-2019, 11:14 PM | #17 |
Ha miss read question !!!! You caught me! My mistake for the year!!!
11-07-2019, 09:20 AM | #18 |
Get a spray bottle and fill with diesel. Spray thru the fill oil and drain out the bottom. I did it to both tranny and rear end when I got my car. The rear end had never been drained since new.
11-07-2019, 09:23 AM | #19 | |
11-07-2019, 12:21 PM | #20 |
It is not a good idea to use STP or Lucas. The high speed gears will fling it out onto the housing. That’s where it stays effectively reducing the amount of oil in the transmission. Stay with 600W oil.
