Old 11-05-2013, 10:08 AM   #21
29Cabriolet
29Cabriolet's Avatar
Default Re: engine side drip pans
Originally Posted by Bob C View Post
Here you go.
Bob
Thanks!
29Cabriolet is offline   Reply With Quote
Old 11-05-2013, 01:36 PM   #22
CarlG
CarlG's Avatar
They are a whole bunch easier to deal with if you tap the holes in the frame and use "hex head cap screws" to fasten them in rather than the bolt/nut configuration that was originally used. I tap them the same as the pan bolts and then don't have to look for anything different when installing them.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 11-05-2013, 03:28 PM   #23
ericr
ericr's Avatar
I did that but then I became concerned that there was not enough beef on the frame rail to get a tight secure connection....
ericr is offline   Reply With Quote
Old 11-05-2013, 03:40 PM   #24
bogiediver
bogiediver's Avatar
Picture of them installed...?
I see a lot of real estate under my roadster, so I guessing I don't have them...
Thanks in advance...
- bogie
'31 (Mostly) Roadster
bogiediver is offline   Reply With Quote
Old 11-05-2013, 03:45 PM   #25
CarlG
CarlG's Avatar
I've got close to 2,000 miles on mine, hasn't come loose yet. I tapped them with coarse threads so as to match the pan bolts. I thought if necessary I could always put a nut on top, but so far haven't seen the need.
Alaskan A's
