Old 03-17-2023, 07:21 AM   #1
Lenny Bruce
Default Spring start up
Hello fellas! This will be my first spring with our Model A. It will have sat for a good 5+ months before being started when the weather finally breaks. Would it be wise to add a little oil in each cylinder and let it set for a spell before initial start up?
Lenny Bruce is online now   Reply With Quote
Old 03-17-2023, 07:23 AM   #2
ronn
Default Re: Spring start up
at 5 months, I wouldnt be too concerned.
MMO and away you go! (in the gas)
Old 03-17-2023, 08:16 AM   #3
Seth Swoboda
Seth Swoboda's Avatar
Just start it. I start flathead V8's that have sat over 20 years without doing much more than checking the oil first. No problems.
Seth Swoboda is offline   Reply With Quote
Old 03-17-2023, 09:00 AM   #4
WHN
Check all your fluids, charge battery, oil distributor and generator, check water level in your battery, I add new gas with Marvel Mystery Oil.
Hit the starter, your good to go.
This comes from 76 years living in the Northeast and putting cars away from November until April/May.
Have a great summer!
Enjoy.
WHN is offline   Reply With Quote
Old 03-17-2023, 09:30 AM   #5
1955cj5
1955cj5's Avatar
I always need to clean the contact area of the ignition points for the first startup in the Spring. I use a points file but mild grit sandpaper or a nail file will do.
I have two other 6 volt vehicles (jeeps) with breaker points ignition but they do not have the same problem.....They are all stored in the same building.
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 03-17-2023, 09:59 AM   #6
Lenny Bruce
Awesomeness thanks !!!
Old 03-17-2023, 10:44 PM   #7
garyjohn
I started my A after sitting 2 years. Fired right up no special doing.
garyjohn is offline   Reply With Quote
Old 03-17-2023, 10:54 PM   #8
ModelA29
ModelA29's Avatar
Kick the tire - light the fire.
ModelA29 is offline   Reply With Quote
