04-08-2019, 01:55 AM | #1 |
shackle studs
Has anyone used nolathane or urathane shackle (stud) bushes? on the springs,
If so how did they go. The shackles on the 33 are not looking too good and have put out enquiries for NOS ones, but needed a backstop if they are not avail. Thanks Lawrie |
04-08-2019, 02:46 AM | #2 |
Re: shackle studs
Yes Lawrie, that's what I've run for years, way to go
04-08-2019, 03:27 AM | #3 |
Re: shackle studs
Fred at Southside obsolete will most likely have NOS.
Barnfind08 on here. |
04-08-2019, 03:47 AM | #4 |
Re: shackle studs
Used them in my last 3 cars and worked out fine.Orig style are a pain to install unless you have the proper tools.
04-08-2019, 05:50 AM | #5 |
Re: shackle studs
Thanks,
I will look into getting some tomorrow. But will still see if I can round up some originals Lawrie |
04-08-2019, 06:09 AM | #6 |
Re: shackle studs
04-08-2019, 04:11 PM | #7 |
Re: shackle studs
Thanks
Lawrie |
04-08-2019, 07:53 PM | #8 |
Re: shackle studs
I have been using Delrin (nylon) spring bushings since the 50's.
I make my own. Slip fit both inside and outside. 2 bushings per hole and flange on one end of each. I like them because if you keep them greased, they never wear out. |
04-08-2019, 08:03 PM | #9 |
Re: shackle studs
Pete, we used to use stuff called polypenco nylon ,I had a small bit left but not enough.
I,m going out to look for some this morning. Lawrie |
04-08-2019, 08:07 PM | #10 |
Re: shackle studs
I still use moly filled Delrin. It is available. Not sure in the "outback" though.
04-08-2019, 09:00 PM | #11 |
Re: shackle studs
Nylon in 2002 for my F1, 80,000 Miles, no worries.
Bruce
Works good Lasts long time |
04-08-2019, 09:42 PM | #12 |
Re: shackle studs
Moly impregnated Nylon 6/6 in my '41. Installed them in 1995 and were still good when we sold it in 2017. May be able to get the bushings in correct size thru McMaster-Carr Supply. I made mine like PETE with flange
04-08-2019, 09:49 PM | #13 |
Re: shackle studs
I’ve done both original and Poly , poly bushings are so much easier, I ended up drilling the shackle pins for cotter pin’s and castellated nuts so they look original from the outside.
04-08-2019, 10:15 PM | #14 |
Re: shackle studs
Run pete and jake shackles up front on the 38, Poly bushings. Rear are bolts with drop shackles and poly bushings. So far so good. The older new versions of nylon bushings hollowed out after a year. Don't like putting anything thing with nyla-nuts on my truck, castle nuts and pins.
Not sure why you couldn't use the original studs with Poly bushings??? maybe someone could add. |
04-09-2019, 01:59 AM | #15 |
Re: shackle studs
This arvo I made a set using nylon poly stuff from the bearing supply Co.
Looks good,easy to do and used the repo shafts from the repo studs,will fit them up tomorrow. We have a 2500 trip out to winton in the next few weeks so that will be a test to see how they go. Lawrie |
04-09-2019, 04:20 AM | #16 |
Re: shackle studs
Its available on Ebay I brought some and had it shipped to New Zealand no problems . Turns beautifully on the lathe -Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
