Old 12-19-2019, 07:35 AM   #1
Ed in Maine
Default 31 Victoria Ampere Meter
I am going through my 31 Victoria and the item that stands out is that the ampere meter stays on zero. I have a new battery and the car came with a 6v alternator. The car runs perfectly. Looking at the schematic it looks to me that the ampere meter may be defective. No charging or discharging is indicated. Since the car starts and runs nicely, it must be the movement portion of the ampere meter. Any other thoughts? Thank you, Ed
Old 12-19-2019, 07:40 AM   #2
eagle
eagle's Avatar
Default Re: 31 Victoria Ampere Meter
A good battery will last quite a while without the charging system working. Use a good quality voltmeter , check the voltage right on the battery with engine off, then running at a high idle.
Old 12-19-2019, 07:44 AM   #3
marty in Ohio
marty in Ohio's Avatar
Ed,
If you have to get a new amp meter, good luck. I bought one a couple years ago from a good supplier and before I installed it the needle fell off the post. I called my supplier and they refunded my money. I offered to send the defective part back and they told me "throw it away, the part was junk any way."
Marty
marty in Ohio is offline   Reply With Quote
Old 12-19-2019, 10:19 AM   #4
Badpuppy
Make sure it's a 20-amp meter. With alternator and new battery a larger capacity ammeter may not provide enough deflection to notice 1-2 amps charge.
Old 12-19-2019, 10:21 AM   #5
katy
katy's Avatar
FWIW, for the uninformed, the proper terminology is ammeter.
Old 12-19-2019, 10:56 PM   #6
Mike V. Florida
Mike V. Florida's Avatar
If you remove one wire from the meter and the car will not start then you have a bad meter. If the car still starts then you have a wiring error'
Mike V. Florida is online now   Reply With Quote
Old 12-19-2019, 11:43 PM   #7
Stew Masche
Stew Masche's Avatar
I had a poor quality reproduction that would occasionally stick. try tapping it lightly while the car is running to see if it will move. Tap too hard, it may fall apart. Good originals can also be found at swap meets, etc.
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 12-19-2019, 11:47 PM   #8
Synchro909
Synchro909's Avatar
Try turning on the lights or sounding the horn without the motor running. Watch the ammeter and see if it shows a deflection. If yes, things are looking good. If no, you have a wiring issue or a dud ammeter.
Old 12-20-2019, 02:50 AM   #9
Bill G
Bill G's Avatar
Had it been indicating a charge/discharge previously and then quit?
Old 12-20-2019, 06:53 AM   #10
marty in Ohio
KATY,
You know, I thought the correct term was ammeter also, but before I responded in post #3 I looked in the Snyder's book and they called it an "amp meter."
Go figure.
Marty
Old 12-20-2019, 11:40 AM   #11
Badpuppy
"Ammeter" is the correct term, but since it's a shortened version of "ampere meter" I see nothing much wrong with "amp meter". Just sounds a little odd to those of us who use the term often in our professional work.
Old 12-21-2019, 12:39 PM   #12
rocket1
How many amperes is the ammeter reading! English go figure.
rocket1 is offline   Reply With Quote
