Old 09-07-2019, 09:11 AM   #1
rfitzpatrick
Default Lite Bulbs
Where can I find the old style lite bulbs, 6 volt, that screws into a socket. Not wanting the ones that slid&twist.
Thanks
rfitzpatrick is offline   Reply With Quote
Old 09-07-2019, 09:47 AM   #2
katy
katy's Avatar
Default Re: Lite Bulbs
What size of bulb? Do you have a part #?
Something like this? https://www.jacksonelectricsupply.co...-p/cec1482.htm
Old 09-07-2019, 01:00 PM   #3
Patrick L.
Patrick L.'s Avatar
Hmm, I don't remember ever seeing such an automotive bulb.
Old 09-07-2019, 02:49 PM   #4
Keith True
Keith True's Avatar
I've never seen them in automotive use either.But,that doesn't mean anything.There are thousands of things I never heard of until I do.i thought maybe they were for a lantern type light,I have some old fire department and Ray-O-Vac lanterns that use 6 volt bulbs,so I checked them.They all take a bulb with a plate,and a collar screws down over them.
Old 09-07-2019, 09:27 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
It would help me if you were to list the use of such a bulb. Do you have a picture of the old one? Does this go into a turn signal?
Old 09-08-2019, 08:55 AM   #6
katy
katy's Avatar
They were used in some early car radios for a dial light.
Old 09-08-2019, 10:30 AM   #7
Patrick L.
Patrick L.'s Avatar
OK, interesting
Old 09-08-2019, 10:45 AM   #8
rfitzpatrick
Thanks and yes they were. I'm trying to find them as I'm working to install a radio controller and box in my PicUp. I've some other lite accesories I'd like to lamp. Nothing is being installed that can not be removed and returned to original.
Again Thanks Guys
Old 09-09-2019, 11:35 AM   #9
Badpuppy
https://www.bulbtown.com/Midget_Screw_Base_E5_s/311.htm
Lists several 6V bulbs, difference is brightness. Behind the dial should be pretty dim - probably #372. Might be bigger - https://www.bulbtown.com/category_s/328.htm
