02-12-2017, 12:39 PM | #1 |
Spring Perches: What Have I Here?
Recently received a box of ‘stuff’ from a friend. Amongst the treasures are what appear to be NOS spring perches. However ...
Comparing them to the RG&JS (pg 4-3; 2011), clearly they are not Style 1 (arched). While they are ‘straight neck’, other dimensions don’t compare well to Style 2 or 3 either. * Shoulder: ~1” wide x 1/4” thick. {Style 2: 1/8”; Style 3: 1/32”} * Neck: 0.8” thick; ~0.5” (inside) ~1.1” long (outside) ..... RG&JS do not provide dimensions. Guess could be the camera angle of the JS photo but these seem to have a ‘shorter’ neck length … Although apparently well made, I’m suspecting ‘repro’. Thoughts? Dont want to misrepresent them if i decide to resell. Last edited by Charles Reese; 02-12-2017 at 12:59 PM. |
02-12-2017, 12:47 PM | #2 |
Re: Spring Perches: What Have I Here?
can you post a pic sideways also,,, they seem to be early repos...
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
02-12-2017, 01:00 PM | #3 |
02-12-2017, 01:04 PM | #4 |
02-12-2017, 01:10 PM | #5 |
02-12-2017, 01:13 PM | #6 |
I would not need it though. I discovered that my car has a 1948 front axle instead of the 1947 one and the newer axle has a hole already in the axle for the shock mounting bolt. Somebody in the earlier line of ownership did me a big favor with that axle! Last edited by Cool Hand Lurker; 02-12-2017 at 01:20 PM. |
02-12-2017, 01:16 PM | #7 |
I think the gentleman meant to say ....original post...., not thread. He believes them to be reproduction. I know Warshawsky & Co. sold '32-'34 perches BITD, maybe they had Model A perches too. I had a set of the early V8 perches, they were Argentine repros, forged, but the machining was kinda poor on the V8 ones. Are those forgings?
My school colors are black and blue, I attended the School of Hard Knocks where I received a Masters Degree in Chronic Mopery. |
02-12-2017, 01:30 PM | #8 |
02-12-2017, 01:40 PM | #9 |
The area right above the tapered area is not like any originals that I have ever seen. I think you perch bolts in your pictures are repros, but not like the ones I bought that were from Argentina many years ago before I wised up. The originals I have seen have a somewhat sharp edge to them directly above the wishbone. The perch bolt in your picture have too much of a cylinder in that area. Below is an original perch bolt.
Rusty Nelson |
02-12-2017, 03:41 PM | #10 |
Check the cotter pin hole. Some of the early repros had the hole going from front to rear and all the original i have seen have the hole going left to right.
Bob |
02-12-2017, 03:56 PM | #11 |
I agree with Rusty. They are likely repro, as my originals look like Rusty's picture, and the repro's I've worked with are thicker in many areas. If fact I had to grind away some metal to use repro perches on the 29 Roadster I worked on.
02-12-2017, 04:45 PM | #12 |
The big thing for me is the beefyness of the shackle hole. The originals are almost dainty and the repros are all beefy. See how the originals also kind of taper to the end.
Once you key in on that you tell them from a distance laying on a table. There are other things like the markings and just the overall look of the metal and machining. |
